CA Smog Help, Ignition Timing
I just bought a 90' si HB out here in San Diego and I am trying to pass the smog test. I am running a Dohc ZC, but I would to try to get it pass a shop who maybe doesn't know too much about hondas.
My Ignition Timing is at 22 deg. I need to bring it down to 18 deg. From my research this should help my emissions. I do not know what the proper ignition timimg is on ZC engine, and i am hoping that adjusting this will not affect my car in a bad way. Will it?
Thanks for the help in advance
I can let you know where I took mine to smog if you're still here in San Diego. It's been a while but I bought some stuff off of you YEARS ago.
I got my jdm dohc zc to pass in cali at a sac shop failed with a pg7 ecu and 91 octane but I got it to pass with a pm6 and 87 octane. Barely did it but it was tested like a 1.5l sohc because that's what my BAR sticker says. lol
Ditto on the ECU. It passed once with the PG7 but the tech had to run the test a gear lower than normal. After putting the PM6 ECU it never had a problem.
Unfortunately, the seller got deported back to Mexico, so he is no good to me now.
I am running on a PM6 ECU, oil change, run hot, and 91 octane hopefully I will pass.
Thanks for the info guys.
See if your shop can do a pre-test first rather than a real test.
It might cost you a little (might not) to have them do this for you.
The idea is to see your numbers before it gets sent in as a real test.
If you are worried that it might fail miserably then it's something to consider.
drastikmeasurez
20
Feb 3, 2004 08:17 PM
GroundZer0
Aug 26, 2002 03:07 PM
