misfire help me please
Old Mar 5, 2012 | 06:56 PM
hondaaccordf23's Avatar
Default misfire help me please
changed spark plugs and wire still misfires help plz
2000 honda accord ex
P0304, 0302, 0300, 1399
Old Mar 5, 2012 | 08:04 PM
GhostAccord's Avatar
Default Re: misfire help me please
Did you find what you were looking for?
Did you ever notice if your check engine light was flashing when you were driving with the engine under load (up a hill or under acceleration) or at higher RPMs? Did you ever notice any hesitation while driving? if so how long has this been going on? Or was it instant with no previous indicators?
P1399 or was it P1300? P1300 is a random misfire code. Set off by any misfire issue.
P0300 - same Random
P0302 - Cylinder 2 misfire
P0304 - Cylinder 4 misfire
Randome issue could be;
EGR system
Fuel system
Ignition system
IAC valve
Contaminated fuel / lack of fuel
The cylinder specific cuts it down to;
Fuel injector/circuit
Ignition system
Low cylinder compression
Improper valve adjustment
Start wit the easy stuff and work your way down. Check your plugs, wires, cap and rotor for unusual wear. If you have a volt meter you can run some tests on your ignition Coil and ignitor. Check to make sure that your fuel injector plugs are clean and secure.
Old Mar 5, 2012 | 09:37 PM
well I have low Compression in cyclinder 4
Vince24L
May 14, 2025 10:33 AM
wanda robinson
Mar 18, 2017 08:25 AM
Chargerhemi06
17
Sep 29, 2014 06:44 PM
Tucker33
Dec 16, 2013 09:40 AM
luis83190
Dec 6, 2009 06:14 AM
