Is the 96-00 Civic hood fuse box the same for manual and auto transmissions?
hello HT i was wondering if anyone could tell me if 96-00 under hood fuse box is the same for manual and autos ... ive tried to look it up but found out that it might be a dumb *** question cuz i found nothing..
reason for asking i have a 99 em1 and the battery drained on me... i have cels pertaining to:
p0133: a/f sensor 1 response malfunction (exhaust leak, short , o2 problem?)
p1298: electric load detector (ELD) circuit high input ( checked the #15 fuse it was fine, i have no IM bracket, will check wire harness this weekend)
p0138: 2ndary H02S12 circuit high voltage
p0136: heated oxygen sensor circuit fault
p0450: evap pressure sensor malfunction (gas cap? replaced the subaru gas cap that was on there with a one from autozone(couldnt get one from honda, needed a quick fix))
anyways i kno that was off topic but wanted to give a heads up ive researched everywhere on google n HT, i jump started my car from the clutch and disconnected the battery and the motor stalled, im figureing that it might be the alternator thats bad? or the ELD is the ******* behind it? either way it cannot b fuse 15, i shall take off the alternator n get it tested at an auto store, i will use my brothers fuse box off his 97 ek (manual), double check the harness, tighten the exhaust, after i tighten the timing belt cuz there is alot of play, but i shall be busy working this week, so wont get time till this weekend...
please can anyone tell me if the fusebox is the same for manual and auto 96-00 eks lol or help with the above stated info... thanks HT!
StylezEJ7
Jan 22, 2015 11:25 AM
Montague
Sep 29, 2014 05:26 AM
