crx si ground wires
Old Mar 5, 2012 | 04:26 PM
K20AllMotorEF8's Avatar
Icon2 crx si ground wires
Does anyone know where all the ground wires on my Crx si are located at.?... I'm having trouble starting it up so want to check and make sure the grounds are all hooked up rite.
Old Mar 5, 2012 | 05:10 PM
90civic-ZC's Avatar
Default Re: crx si ground wires
Check the main ones.....valve cover to chassy, tranny to chassy and there's one on your thermostat housing.
Old Mar 5, 2012 | 08:02 PM
Thanks for the info ill double check them all
Old Mar 5, 2012 | 08:14 PM
Stunna MIKE's Avatar
You have an A/M k20 EF8 and you don't know where your grounds are ?
Lol, just bustin' your chops bro. Is your battery in stock location ? or was it relocated ?
Old Mar 5, 2012 | 09:45 PM
Haha Naw I have an all motor b20 Vtec lol the name was all my cuz's doin lmao....the battery is relocated but the reason im askin is cause im tryin to make sure i dont miss any grounds....just bought this shell and the old owner tried to do a wire tuck and chopped all the wireing up so now i got a short for my corner lights and no power to my fuel pump
Old Mar 5, 2012 | 09:52 PM
Make sure the battery is grounded. And make sure the tranny is grounded.
Also, make sure there isn't a fuse between the positive battery terminal and the starter / fuse box. I accidentally did this when I relocated mine. And wondered why I kept blowing the 50a fuse. It's all all the time and doesn't use a fuse there.
Also make sure the ground locations are clean, and your battery terminals are clean.
Old Mar 5, 2012 | 10:10 PM
Yea the positive wire.is ran direct with no fuse bit rite now i dont have a starter on there...all my main grounds are connected ..but now i think there might b a problem with my Ign. Switch because the fuel pump should turn on and flash any codes when I turn the key to the II position nd Dosnt but it does when I turn it to the III Position ...that don't seem rite lol
Old Mar 6, 2012 | 10:15 AM
JDpower's Avatar
I've had those symtoms and for me it was the ignition switch because the II postion wouldn't make contact. It would start and die if the key is not held past II.
Old Mar 6, 2012 | 11:29 AM
I'm gonna try switching the ignition switch then...I think I may have a problem with my dizzy because it makes a ticking noise when the key is turned to the II position and it shorts out because my rpm needle moves up and down and the lights flicker .
crxaggtown
Apr 18, 2007 05:38 PM
MadCityLude
Aug 23, 2006 10:11 PM
tRex99
10
Oct 31, 2004 09:12 AM
dingusjt
20
Mar 6, 2003 09:03 PM
Griffins_Importuning
Aug 29, 2002 09:43 AM
