Suspension & Brakes Theory, alignment, spring rates....
Any input on Koni sport struts with skunk2 springs, Whos got this setup?
Old Mar 5, 2012 | 01:37 PM
eg6bro's Avatar
Default Any input on Koni sport struts with skunk2 springs, Whos got this setup?
Just recently found out my front struts are blown, Did some research on skunk2 sport struts and looks like their not for slammed rides so those fall off the list. Koni yellow sport struts seem to have good reviews for slammed cars so i just want some input from people with this setup? Koni struts, S2 springs.
Old Mar 5, 2012 | 01:47 PM
98civdx's Avatar
Master Detailer
Default Re: Any input on Koni sport struts with skunk2 springs, Whos got this setup?
Skunk2 lowering springs?
A Koni sport could handle those without a doubt.
Old Mar 5, 2012 | 01:54 PM
eg6bro's Avatar
My front springs are skunk2 adjustable coilovers, rear just skunk2 springs.... Bought it that way.
Old Mar 5, 2012 | 02:38 PM
Kohen's Avatar
Why not just go ahead and get the koni/gc setup and sell your skunk2 stuff?
But if you really wish to use junk2 springs, go for it!
Old Mar 5, 2012 | 02:41 PM
Libertariat's Avatar
Ek Forever y0!
This is what I would do.
You'll be a lot happier in the long run.
Old Mar 5, 2012 | 03:59 PM
eg6bro's Avatar
I would if money was not an issue, just looking at front Koni's for now...
Old Mar 5, 2012 | 04:07 PM
Ek Forever y0!
If money is an issue, why are you modifying your car? Or slamming it for that matter? A tactic which often leads to expensive car repairs: wheel bearings, bushings, tires, alignments, body damage, etc.
Konis are not that expensive, and piecing together a makeshift something right now will not be in your favor in the long run. I suggest you wait and buy a complete kit so that everything matches and works the way it's supposed to.
What has being cheap gotten you so far? Where you are.
Old Mar 5, 2012 | 04:27 PM
eg6bro's Avatar
I bought it slammed, already changed the bearings, i can't just drive it with blown shocks. Once again all i was asking if KONI sports where a fine setup with skunk2 springs, and if there's people out there with this setup?
Old Mar 5, 2012 | 04:33 PM
Ek Forever y0!
Yes, people run it. Your standard off-the shelf koni should fit the springs just fine.
I suggest you raise the car up some so as to not experience the same issues in the future. Konis are great, but even they can blow. And no, the warranty won't cover it.
"People," have ran almost every shock/spring combination you can imagine. They are all almost universally interchangeable. Most springs and coil sleeves are designed to work with OE style shocks, and most OE style shocks are designed to work with OEM springs.
It's a mutual two-way street.
Old Mar 5, 2012 | 05:26 PM
98civdx's Avatar
Master Detailer
He won't be able to use the skunk2 coilover correctly without the cir clip adapter from Koni.
It will VOID the warranty.
You should have said you skunk2 coilovers, and lowering springs in the first post.
And Yes you can drive in on blown shocks. Ask me how I know.
Old Mar 5, 2012 | 05:54 PM
Kohen's Avatar
How do you know?
Old Mar 5, 2012 | 06:10 PM
eg6bro's Avatar
Yes, i know you could drive on bad shocks.... its just that the ride gets bouncy.
Old Mar 5, 2012 | 06:55 PM
98civdx's Avatar
Master Detailer
You'll have to get used to it. Skunk2 suspension products aren't comfy.
da.nizzle
Suspension & Brakes
Nov 6, 2008 07:38 PM
white98gs-r
Jul 1, 2008 06:53 PM
rsx-vt
Jun 2, 2003 02:50 PM
teg96
Mar 19, 2003 02:38 PM
