D16Y7 EK not starting (fuel?)
Hey HT, never asked for help from here but I have done extensive searching and I'm left here.
I have a 96 DX hatch, that HAD a b16 in it but someone wanted to buy it ASAP so I sold it to them for a good amount. Well I picked up a d16y7 for nothing, just had to buy a harness.
Problem is the fuel pump will not prime. I jumped the 5 and 7 pins of the main relay and it did prime. I have 2 main relays, one I bought new from honda 6 months ago, another out of a em1 that worked when i removed a few months ago. I checked the solder points and they were all good. Still nothing.
All grounds are good, tranny, VC, and thermostat (which wasn't hooked up before, but it is now) Still nothing.
Fuses are good, namely number 24, the fuel pump, underdash is fine and all the under hood ones are fine. Still nothing.
I've been alone all day so I haven't really been able to check spark or anything. When I jumped 5 and 7 it finally put fuel in the line but still nothing.
I'll try a different ECU tomorrow, but this motor ran less than 3 weeks ago on all the same stuff.
If anyone can give me some things to check tomorrow when my buddy is over I'll give it a full run down.
Another thing, my CEL light will not light up. I've tried at least 3 different bulbs from other slots on the cluster but it still doesn't illuminate when the key turns over, Any idea?
codysf30
13
Mar 27, 2019 09:45 PM
