How to "center" my steering wheel?
Old Oct 10, 2002 | 09:47 AM
jabroni95gsr's Avatar
Default How to "center" my steering wheel?
It is like 1 degree off, it sort of annoys me. If there is an easy fix, please tell me...if its not worth it, just tell me that too. thanks
ps- anybody switch their srs out for a momo or something non srs?
Old Oct 10, 2002 | 09:49 AM
CTR94Joes's Avatar
Default Re: How to "center" my steering wheel? (jabroni95gsr)
Yeah I swaped my SRS (94 Civic) for a JDM ITR MOMO and now my damn horn doesn't work.
Old Oct 10, 2002 | 11:31 AM
ajchen's Avatar
i think you might need an alignment.
Old Oct 10, 2002 | 11:36 AM
erniecars's Avatar
Default Re: How to "center" my steering wheel? (ajchen)
my steering wheel is crooked too so i swapped it with another of the exact same one and nows its strait. I think the first one was just made a tiny bit off.
Old Oct 10, 2002 | 12:16 PM
junglistgsr's Avatar
Default Re: How to "center" my steering wheel? (erniecars)
probably need an alignment.
Old Oct 10, 2002 | 01:32 PM
au-gsr's Avatar
Default Re: How to "center" my steering wheel? (junglistgsr)
if your wheel isn't straight then get an alignment, if your head isn't straight then hit vtec in fifth gear or take a bong hit, clarity my friends, CLARITY!!!!
Old Oct 10, 2002 | 03:34 PM
DRFlickner's Avatar
Pull your wheel off and move it over by one spline. Just keep moving it until you get it straight. I had the same problem when I put my MOMO wheel in my Integra and in my Civic. BTW, I wasn't able to keep my horn/airbag in the Integra, but it is possible to rig up some wiring.
Old Oct 10, 2002 | 10:20 PM
3rdGteg's Avatar
Default Re: How to "center" my steering wheel? (DRFlickner)
I'm having the same problem. My airbag blew in my 96 teg and got a steering wheel assembly from a 00 teg and for some reason, I can't line the splines up to make it straight like my 96 steering wheel--maybe they're made off a little from each other
Old Oct 29, 2002 | 08:19 PM
Default Re: How to "center" my steering wheel? (3rdGteg)
my car is aligned (thank you very much but i need to just double check how to move the wheel over a spine...do i just unhook the battery, take the plastic panels of the wheel on the sides off (do i even need to do this?), or can i access this from underneath?
thanks for all the help.
Old Oct 29, 2002 | 08:47 PM
Brian_92GSR's Avatar
New User
I think it's highly unlikely that Honda messed up on a wheel and made it a tiny bit off. If the wheel isn't straight and it's never been messed with, you just need an alignment. If it has been taken off before and you can't get it back on straight, again, alignment.
Old Oct 29, 2002 | 09:32 PM
Maverick77's Avatar
Default Re: How to "center" my steering wheel? (Brian_92GSR)
Sounds like an alignment bud
Old Oct 30, 2002 | 10:07 AM
zilverz's Avatar
If anyone has replaced the Steering Rack .. it could be miss aligned somewhat ... i think there is a section in the Helms about aligning it back properly but i got 2 integras and ive been working on the electronics and engine ... havent had time for cosmetics and fixing the Airbag and horn (;
NEO_FOLLOWER2
Jun 13, 2011 03:56 AM
Rob.
Mar 30, 2006 07:04 PM
PleaseHelp
Sep 14, 2005 09:29 PM
lewdude
Sep 28, 2004 10:06 PM
citanest
Apr 21, 2002 01:15 PM
