2000 Accord Coupe stalling while driving
Old Mar 3, 2012 | 04:43 PM
David Grober's Avatar
Default 2000 Accord Coupe stalling while driving
I have a 2000 Honda Accord Coupe 4 cylinder with 85,000 miles. It has stalled while stopping in the past a few time with easy start up. Stalled once in a parking lot and would not start for 20 minutes. Replaced the Main Relay. Seemed to be fine after that.
But today it stalled while driving at speed twice. The dash lights did not come on as I coasted. I noticed on the web this is due to the ignition switch? my VIN on owners link says its not recalled. Any other ideas what it could be? If you think its the switch how do I get them to Fix it under recall?
Thanks,
Dave
Old Mar 5, 2012 | 02:17 PM
Lost Again's Avatar
Default Re: 2000 Accord Coupe stalling while driving
Test it to be sure but I'm 90% sure (based upon the description) this is the switch.
Simple test, when it does this, see if you have 12v on the BLK/YEL wire going to the dist.
Old Mar 5, 2012 | 02:54 PM
Thanks for the reply.
Its an intermittent problem, but will check next time it occurs.
Does anyone know the part number #s I need to fix this??
Dave
Old Mar 6, 2012 | 04:41 PM
Lost Again's Avatar
Let's wait to see what the issue is first. If it is the electrical part of the switch, there are a few options (dealer, aftermarket).
Old Mar 7, 2012 | 04:50 PM
I tested the continuity of the switch and it failed.
What options do I have ? Are the aftermarket switches better or as good as the oem?
Old Mar 7, 2012 | 05:11 PM
Lost Again's Avatar
Kind of a debate, not wanting to start one.
Personally, I'd go aftermarket but that is JUST my opinion. Others will have theirs.
user 972868
Jul 26, 2023 09:50 AM
ldutton
Jan 25, 2013 02:48 AM
jose6382
May 26, 2012 10:45 AM
bestint
Oct 27, 2010 12:24 PM
stnwag0n
Jan 1, 2004 06:08 PM
