1999 civic ex coupe-manual transmission-popping out of second gear??
Old Mar 3, 2012 | 02:05 PM
bee743's Avatar
Icon2 1999 civic ex coupe-manual transmission-popping out of second gear??
Hi-I have a 1999 Honda Civic ex coupe-I've been noticing that the manual trans. will pop out of second gear sometimes shifting from first to second.I just had a new clutch installed last week and thought that would have taken care of it.Other than that the car drives great and shifts normally into all other gears,it's only second gear that is the issue.Does anyone know what might be causing this,and roughly what the cost might be to have it repaired?
Any info. would be greatly appreciated.thanks
Old Mar 3, 2012 | 02:08 PM
Arthas's Avatar
Default Re: 1999 civic ex coupe-manual transmission-popping out of second gear??
Clutch swaps usually dont repair issues like that.
I would try changing out the fluid with Honda MTF and hope for the best. If that doesnt work just purchase another rather than getting it repaired.
Old Mar 3, 2012 | 02:25 PM
suzieffbaby's Avatar
from what it sounds like, you need a new transmission. i think it'll probably be cheaper to get new one rather than fix it.
Old Mar 3, 2012 | 02:27 PM
94EG8's Avatar
Seagull Management
Bottom countershaft bearing walked out of the case. You need to split the case, tap the bearing back down and stake it there with a center punch. You might want to replace the input shaft bearing and seal while you're in there.
Brian Lewis
Transmission & Drivetrain
Dec 6, 2018 02:06 AM
Tabby2
Honda Civic (2001 - 2005)
Mar 17, 2018 09:01 PM
trowe
Sep 2, 2013 06:26 PM
DCRB
Apr 7, 2013 11:07 AM
Mr Trip C
Jul 31, 2008 04:08 AM
