How 2 remove injectors from fuel rail?
I have both the OEM and Chilton shop manuals for my 95 Accord LX. It is not clear how to remove injector from fuel rail. I want to replace rubber bits.
Do they just pull out? Are they threaded and you un-screw them? Rail/injectors already off the intake manifold. Just need confirmation on removing injectors from rail. Don't want to break them, so I thought I would ask the Accord gurus here.
Thx!
Mike
Thx!
Mike
They are slip fit, no threads. Just pull them out and push them back in. When you go to put them back in you could put a dab of oil/gas/spit around the o-rings to help them slide in. Lubricated is much easier than forcing them in dry.
B16Jacques
Jun 15, 2005 08:25 PM
Dancing is Forbidden
Jun 16, 2004 05:24 AM
