Skunk2 LCA and OEM sway bar Endlinks?
Hi guys, i just got S2 LCAS to replace my BLOX lcas on a 2000 si em1, when doing the install i noticed that the Rear sway bar end links are far too short to pass all the way through the LCA and be secured at the other side, its threaded and screws in roughly half way through the LCA
im using OEM endlinks on my stock si swaybar, is anyone running this? is it ok to have it threaded only half way through without a nut? the BLOX ones went all the way through and werent threaded, and secured on the other side.
The OEM endlinks and Blox go all the way through on mine. The stock ones do not get a nut on the other end because they are not as long. Is that what you are talking about? How do you think it would even manage to work itself free?
i guess technically it shouldnt spin or come out of the threading, but it just makes me nervous that so little amount of thread is holding the endlinks on, i guess just screw it in and let it be???
thanks i put it in,
Another noob question, can anybody point to me where the Rear Toe adjuster is? mine is "seized" according to the alignment shop and i cant align the rear of the car, i want to make sure it actually is frozen and cant be un-siezed..... if anyone could show me where it is on a 99-00 si chasis,
thanks!
thanks!
thanks i put it in,
thanks!
thanks!
Its actually called a Compensator Arm... They seize often. Heat it up with a torch!!
Soak it in areo-kroil and try loosening it with an impact. Short bursts, don't just grab it...
Hopefully you can break it loose without actually breaking it. It's a bitch and a half to replace it.
are you sure you have the right control arms? if you have the ones pictured in your original post, those are for 92-95 civic and 94+ integra. 96-00 civics have them more in the middle and are through holes, not threaded.
bleedblue94
Suspension & Brakes
14
Mar 29, 2009 07:57 PM
mystikz2002
May 7, 2005 09:00 AM
