imported H22a, WHAT ECU do i need
OK, i purchased a H22a engine from japan a couple years back because i wanted to do the H23 swap. I tried wiring the vtec myself. so i bought a p13 ecu because thats what i thought was the correct ecu for my engine. it ran like ****. so i put the p14 back in, it runs beautify just no vtec. please help
if u need more info please ask
Which fuel injectors are you using, and what wiring harness, internal or external coil etc? The P13 is what should run the Jdm engine, but some other things have to be done right as well.
i cant remember which injectors i used because i did the swap like a year and a half ago, but the harness is from the h23 and its the external coil, i'm just getting my license back so i wanna get her runnin right
StickyDilJoe
Aug 29, 2002 01:36 AM
