hot start issue
Old Mar 3, 2012 | 05:25 AM
sl0waccord's Avatar
Default hot start issue
Every time I shut off my car for a few minutes and then go to turn it back on the Damn thing wont start. I have to sit and wait for 15 minutes before the fuel pump will switch on even after swapping out the relay. What can i do to fix this other than just letting the car idl3?
Old Mar 3, 2012 | 05:49 AM
phootbag's Avatar
Default Re: hot start issue
How did you confirm an inoperative fuel pump?
Old Mar 3, 2012 | 07:57 AM
jwicecold's Avatar
It actually is more then likely your battery!! I had the exact same problem, only to come to find out my battery never held a full charge. Changed it never had the problem again!! Now my VW Jetta does it. I charge the battery for awhile and stars right up NO PROB... Def Test battery with a voltage meter!
Old Mar 3, 2012 | 10:04 AM
sl0waccord's Avatar
It's not the battery. I can sit here and let tje car turn over for 5 mins no problem. I am assuming the fuel pump relay due to the fact that usually when I replace it I am good for a few months. Now I have a new one in and it still won't start if I let it sit for a few mins. I have to sit and wait 10 mins for it to start up again
Old Mar 3, 2012 | 01:16 PM
phootbag's Avatar
Ignition coils can have a hot soak malfunction.
You should confirm if the problem is a loss of ignition or a loss of fuel. It's not common for a loss of compression, air or timing to cause intermittent hot-soak no-starts.
Therefore, I would start by confirming spark. It's the easiest to confirm. If spark is fine I would inspect the fuel system.
Old Mar 3, 2012 | 03:13 PM
sl0waccord's Avatar
That is interesting I will check out the coil tomorrow.
fog raw
Jan 28, 2012 06:52 AM
woodwardba0526
Honda Civic (2001 - 2005)
Apr 13, 2010 01:31 PM
wreckedmyteg
Apr 20, 2006 09:23 PM
Jolf
Aug 14, 2003 03:44 AM
