b16 running rich
Old Mar 2, 2012 | 08:35 PM
SoCalEjay1's Avatar
Default b16 running rich
Hi all, I have a 93 Coupe with a 99' b16a2 swap running a Erick's Racing chipped P30. It runs very rich. I recently purchased the car as a daily driver and love it. What would be my best option for getting better gas mileage? Would I be better off with a P2T? I also need it to run clean for smog purposes.
Thanks.
Old Mar 2, 2012 | 08:39 PM
98civdx's Avatar
Master Detailer
Default Re: b16 running rich
Wont be worth it to run the Si ecu.
You need to have it dyno tuned!!
Old Mar 2, 2012 | 11:18 PM
Lil Gnome's Avatar
Run a Stock MAP or get a tune if the ECU is the issue. But check around the engine. Dirty air filter?
Old Mar 3, 2012 | 04:05 AM
grumblemarc's Avatar
The Grumpiest
Get a better MAP. Call Phearable and get a new chip.
Old Mar 3, 2012 | 07:17 AM
Red_Army's Avatar
why get a tune from what's been said a stock b16?
get a different ECU and MAP.
Old Mar 3, 2012 | 07:27 AM
BobbyRodriguez's Avatar
Cheaper if your ecu has a removable chip
Old Mar 3, 2012 | 07:33 AM
The Grumpiest
Please be quiet. If it's chipped then it HAS to be socketted to do it. That means that the chips are swappable.
Old Mar 3, 2012 | 07:57 AM
eg6 type-R's Avatar
LOL..
grumblemarc is right on this
Old Mar 3, 2012 | 08:30 AM
simplejackk's Avatar
I run a P72 ecu on my b16a and it runs just fine and gets great gas mileage. Picked it up for only 60$.
Old Mar 3, 2012 | 08:31 AM
SoCalEjay1's Avatar
You guys are awesome, thanks for the great suggestions.
@ Lil Gnome, I have a AEM Intake with the conical filter. I will clean it, as I inherited some unknowns.
@grumblemarc, By 'MAP' are you referring to the sensor or the ecu's base map? Im new to playing with ecus, although I have been in the computer field for a long time and have built a jillion servers, desktops... Does rechipping require a great amount of expertise to do?
Thanks Again.
Old Mar 3, 2012 | 08:32 AM
98civdx's Avatar
Master Detailer
The ECU's Map. Like I said, get it tuned.
Old Mar 3, 2012 | 08:53 AM
The Grumpiest
Thanks Again.
MAP in this case means the ECUs operating system.
If you can hold a butter knife you can swap a chip.
Old Mar 3, 2012 | 10:44 AM
SoCalEjay1's Avatar
Im going to call on Monday to Erick's Racing and see if they can reprogram the chip. If that proves unfruitful I will order a chip from Phearable. I have a feeling I am sitting in Open Loop all the time. 17-22mpg for a lil Ej is as bad as my 05 Maxima on gas.
Old Mar 25, 2012 | 07:26 AM
SoCalEjay1's Avatar
I got a new chip from Monotech, he is a member on the Forum. I instantly have gone from horrible mileage to good mileage. My car doesnt smell like an open gas can anymore. I did a few pulls last night and am very happy with the tune. I love the cel shift light. Big props to Mono!
b16 4door
Engine Management and Tuning
14
Aug 12, 2014 03:59 PM
Corksil
23
Jul 14, 2011 05:59 PM
sean from work
Jul 26, 2010 05:54 PM
tdbhonda
Mar 16, 2009 09:51 PM
F20_EG6
Jan 3, 2008 04:36 PM
