How to choose a Manifold properly?
Hey guys, I am in the process of finding myself a correct turbo ramhorn manifold, but I'll need some information in order to pick the correct manifold for my setup. Like the Turbine Inlet Size, Wastegate Size.. Could u guys help me out?
This is the Turbo I'll be using;
http://www.turbobygarrett.com/turbob...t/turbocharger
And these 2 are the Manifolds I am considerign to buy atm.
1.http://www.synapseturbo.com/mm5/merc..._Code=features
2.http://www.speedfactoryracing.net/st...roduct=1650782
thanks in advance
thanks in advance
Either of those manifolds would work....Only real options you need to know for the manifold is if you want Vband hookoup for the Wastegate or bolt on(size will depend on turbo used and goals). And whether or not its d or b series. all of them should have T3 flange for the turbo as a standard.
That link doesnt state what turbo youre using...just that its a garrett.....which is a good thing. YOu need to be more detailed tho
Wastegate size and all the turbo options will be based on youre power goals, and what you plan on doing with the car ( street,drag, autox ect)
crxnug
Aug 2, 2005 05:56 PM
turboekcivic
Apr 27, 2003 03:48 AM
