Ef b16 question
Ok so I put a b16 in my 90 Honda civic SI I changed the plug on the dizzy to obd2(only cause it came with the engine) so Wen I drive my car will die. its like my altunatot won't charge my battery.if I start my car and unplug the battery the car will shut off.Idk wat it is.I took my harness out and sodered the wires but still nothing. Any help is greatly appreciated
Your alternator is NOT working if you can't take the positive battery cable off and have the engine continue to run.
Remove the alt and have it tested - most autoparts stores can do this (usually for free).
I know you stated that it's new, but you could have gotten a brand new malfunctioning one.
If the alt is good, then your wiring is bad.
Simple as that.
Simple as that.
vtec420kingH22
Apr 16, 2009 11:44 AM
