Can someone confirm? Y8 head, y7 distributor, p28 ecu.
Old Mar 1, 2012 | 06:09 PM
Randysi's Avatar
Default Can someone confirm? Y8 head, y7 distributor, p28 ecu.
Can I use the y7 ecu (obd1) on the y8 head with the p28 ecu and still match the vtec ecu? I guess my question here is does it matter what distributor I use on the vtec head. Do I need a distributor from a "vtec" head/motor? Or is the y7 distributor the right one for this. On an A6 block by the way.
Old Mar 1, 2012 | 06:22 PM
90civic-ZC's Avatar
Default Re: Can someone confirm? Y8 head, y7 distributor, p28 ecu.
as long as you use a OBD1 dizzy with your P28 ecu you'll be fine.....and do the correct wiring...unless you already have a OBD1 vtec car.
Old Mar 1, 2012 | 06:34 PM
bradley's Avatar
D16Y8/D16Y7 distributors are the same.
Non-D16Z6/D15Z1 OBD1 distributors are the same.
D16Z6 distributor hits 180 degrees off or some silly thing, I forget. Easy to get around by flipping plug wires 180, I did this when I was given a D15B7 dizzy that had D16Z6 internals because someone dropped a D15B notec in an EJ1 and I guess they thought they had to do that.
That pretty much sums up any dizzy questions. You can use an OBD2 dizzy on OBD1 if you swap plugs or use a conversion pigtail from the dizzy to the harness. OBD1/OBD2 sensors are the same.
You can't use an OBD0 dizzy with anything other than OBD0.
If you meant "y7 distributor", not "y7 ecu (obd1)", then yes you can use it. But it is an OBD2 dizzy and you'll have to swap plugs/use a conversion pigtail. It will work with a P28.
Old Mar 1, 2012 | 11:58 PM
DCRB's Avatar
this is all true
Old Mar 2, 2012 | 02:24 PM
Randysi's Avatar
Thanks everyone for the info!
Old Mar 2, 2012 | 02:50 PM
4drEF's Avatar
Keyboard Humorist
Here's a link to the internal difference.
The correct fix/mod takes a tiny bit of effort, but it can be done.
Just flipping some wires isn't gonna do it.
http://www.tamparacing.com/forums/ho...tec-dizzy.html
Old Mar 3, 2012 | 10:20 AM
Randysi's Avatar
So whats the best option on a distributor to run obd1 with a p28 ecu, a6 block, y8 head, in a 89 civic si?
Old Mar 5, 2012 | 07:59 AM
4drEF's Avatar
Keyboard Humorist
I would go with the Y8 distributor.
It's an easy fit with the Y8 head and it's 100% compatible with OBD1.
Old Mar 5, 2012 | 02:39 PM
Canadian_EF's Avatar
i second this. a y7 is the same too.
don't use a different dizzy for this. the d15 one will always throw a code and never run right even if you swap those 2 wires. i know from experience, not from reading. obd1 d15 is baaaaad for y8. sure, it bolts up... but its wrong.
EFing_Slow
Jan 2, 2017 11:41 AM
Randysi
49
Oct 30, 2011 09:54 PM
jdmjoelol
Dec 2, 2005 08:56 PM
vegaskurt
May 14, 2005 10:17 PM
enabi
Jun 12, 2003 01:06 PM
