B20 Pauter Billet X beam Rods
Old Mar 1, 2012 | 05:23 PM
Boost_allways's Avatar
Default B20 Pauter Billet X beam Rods
Anyone reving 11000+ rpm with Pauter Billet X Beam rods in a high hp boosted B20 motor ?
Old Mar 1, 2012 | 05:28 PM
SPOOLINmatt's Avatar
Default Re: B20 Pauter Billet X beam Rods
shouldn't be a problem. depends on how much ++ you talkin about.
Old Mar 1, 2012 | 05:32 PM
Between 11000 - 11700 rpm
Old Mar 2, 2012 | 11:28 AM
4piston's Avatar
That is a lot of weight to be turning that hard...you will have a lot of crank flex. But the rods themselves are very strong.
Old Mar 2, 2012 | 02:10 PM
My short block is a 84mm Golden Eagle mfg sleeved B20Z2 with
Wiseco pistons & rings + upgraded wrist pins
Pauter billet X beam rods with ARP 2000 3/8 bolts
ERL 5 point main girdle
oem balanced & micro polished crank done by Golden Eagle
ATI race damper for 11000+ rpm
Endyn oil pump
Moroso 5.5 qrt oil sump
Vybrant adjustable timing belt tensioner
electric water pump
Golden Eagle head studs & main studs
ACL Race Performance bearing with DFL coating
ClutchMasters 700 series twin
ARP flywheel bolts
ARP damper bolt
Toda Racing timing belt
4 FULL-RACE dowel pins for VTEC head setup
Midori Green
12
Apr 9, 2008 08:12 AM
killa_D
Mar 31, 2007 04:52 AM
Infinite Auto
Aug 27, 2005 01:58 PM
