LSV Build
Old Mar 1, 2012 | 05:02 PM
on1xv6's Avatar
Default LSV Build
i planning to build this on april
(Looking for 180+WHP with OEM Part)
for my Em1
B16a2 Head P&P 3 angle Valve Job
ITR Valve train
ITR Cams
ITR Intake Mani
Edelbrock 68mm TB
AEM FRP
Tranny
ITR LSD
6 Spunk Clutch
Fidanza 8 lb flywheel
BM Short Shifter
LS B18B1 Block 81mm
CTR Piston
APR Head Studs
ACT Rods Bolts
OEM Head Gasket
Innovative motor mounts
Invidia Exhaust
Tri Y Header
AEM V2 intake
any one have something similar?
any suggestion?
Old Mar 1, 2012 | 05:10 PM
grumblemarc's Avatar
The Grumpiest
Default Re: LSV Build
What's the question?
Old Mar 1, 2012 | 05:49 PM
hannslebo's Avatar
I think he is just asking if this parts list is okay. Or what else does he need...stuff like that...
Bore it! 81.5mm - Might as well, get a little better TQ numbers.
Old Mar 1, 2012 | 05:59 PM
JDM_teh_WIN!!'s Avatar
Most people use JDM B16 pistons. Unfortunately I don't think they make them oversized anymore (81.50mm). You will most likely need to at least hone the cylinders if not bore them. That puts OEM piston out of the question since it is not available. Nor do they make a 82mm piston. You will have to go with aftermarket pistons or use a JDM ITR piston.
Old Mar 1, 2012 | 06:00 PM
k3vmaster's Avatar
nice
Old Mar 1, 2012 | 07:48 PM
SKAVENGER88's Avatar
Go with aftermarket piston heads
Old Mar 1, 2012 | 07:52 PM
Go to the all motor dynos. Alot of ls/vtec build on there
fastlittlecivic69
Sep 5, 2010 04:24 PM
RACING INTEGRATION
10
Dec 10, 2007 12:56 AM
Echo7847
15
Apr 23, 2007 08:22 AM
92redgsr
Apr 13, 2004 10:12 AM
92redgsr
Mar 20, 2004 04:06 AM
