94 accord passenger side low beams not working
A couple of weeks ago a few of my guys changed out my radiator support. After everything was finished we put everything back together and everything worked fine except for the passenger side low beams. Highbeams work fine. I went to a junk yard and grabbed a new connector harness and everything but still no luck. Anyone have any ideas where I should go check next?
did you check the bulb itself?
yank it out and physically see the wire
besides that, check the wiring to that bulb <shrugs> with a voltmeter
All my fuses look fine. This issue really blows
wiring issue. check your pin out in the back side of the bulb it should be tight. if not play with it a bit and see if it works. also check the ground for the lights
were you in a front end wreck? wire might be cut/pulled somewhere
get a test light to check your low beam circuit, check for a good ground and 12 v when you turn the light switch on, then trace the wire (which ever one don't work) to see if you guys accidently kink/broke/grounded somewhere
accord ex
Mar 13, 2003 05:55 PM
