can i put fiberglass filler to fix my polyurethane front lip
Old Mar 1, 2012 | 12:13 PM
EG-SIXV-TEC's Avatar
Icon2 can i put fiberglass filler to fix my polyurethane front lip
Hi i want to know if i can fix a polyurethane lip with fiberglass filler duraglass? Will it hold and bond good?
Old Mar 1, 2012 | 01:17 PM
TunerN00b's Avatar
Default Re: can i put fiberglass filler to fix my polyurethane front lip
You can do it, but it won't hold well.
Plastic welding. Why you'd consider filling with a different material when the junkyard is full of the same material, I can't imagine.
Old Mar 1, 2012 | 01:26 PM
can i use the plastic weld thats in a tube i saw in an autostore. can i sand it then add filler bodyfiller or fiberglass over it
Old Mar 1, 2012 | 01:48 PM
TunerN00b's Avatar
Where's the facepalm emoticon?
Get a scrap bumper of the same material. Heat and melt the scrap into your damaged piece. Work with just plastic, no filler, no fiberglass.
Skip the epoxy in a tube. Glue is not welding.
Again,to repeat myself:
Old Mar 1, 2012 | 07:52 PM
ej6sir-t's Avatar
post pics of what ur tryin to fix
Old Mar 6, 2012 | 11:03 AM
c1hatch's Avatar
3m 5887. Flexible plastic repair. U will need a bottle of there adhesion promoter as well. Try and fix things with same/ like materials. Different materials shrink and expand differently and will show up in the repairs later on.
Old Mar 6, 2012 | 02:42 PM
.hawaii's Avatar
im guessing you have a fake type r lip? why not just buy a real one instead of spending money to fix a fake one?
Old Mar 6, 2012 | 03:35 PM
siblues's Avatar
I dont understand what is the real one made of?
On another note listen to what the guys in here are telling you try to use the same material to fix the lip you can use fiberglass to fix it with no issues but its much harder to get a crack to keep from showing signs of the repair in the longrun.Lips tend to get hit or hit things often and it will usually cause the fiberglass to seperate from the urethane/plastic that the lip is made of.
Old Mar 12, 2012 | 07:14 AM
jdmgsr98's Avatar
dude go to a napa and they have poly urethane body filler.. its in a small tube and its red
Old Mar 12, 2012 | 11:48 AM
gorillafart's Avatar
you shouldnt use fiberglass filler on a plastic piece, mainly because the plastic piece is meant to be flexible... cured fiberglass filler is not.
plastic welding still works, but is an out dated method... you should go with what has already been mentioned in this thread, and that is:
sk8shorty012
Feb 6, 2006 06:06 PM
tkosmith
Jun 16, 2005 01:00 PM
digital sol
Welding / Fabrication
Mar 16, 2005 08:01 PM
pr_tony_montana
Nov 13, 2004 03:52 PM
Proper
36
Nov 9, 2004 12:59 PM
