How do you remove my door handle.
Old Mar 1, 2012 | 11:02 AM
Jakester9500's Avatar
Default How do you remove my door handle.
Car: 2000 Honda Civic EX
Problem: Cant remove the exterior door handle
I looked up online but there wasnt a whole lot. I have a picture below. I have removed the (2) 10mm bolts, I have taken off the rods, and I have taken off that little clip, the spring and a white plastic piece that held the spring together. I am pretty sure this aluminum piece and gun metal colored piece has to come off but I cant figure it out.
Old Mar 1, 2012 | 11:06 AM
Mikasa's Avatar
Default Re: How do you remove my door handle.
By little clip do you mean the "U" shaped one that goes behind there?
Old Mar 1, 2012 | 11:15 AM
kyden's Avatar
there's a U shaped clip behind that assembly, accessed by the hole right above the lock.
Old Mar 1, 2012 | 11:28 AM
There was a U shaped clip that I have already removed that would have been in the picture if its assembled right now. Its visable when looking directly at it.
So are you saying there is a U shaped clip behind the aluminum piece or the gun metal colored piece?
Old Mar 1, 2012 | 12:00 PM
Mikasa's Avatar
It's behind the aluminum piece. Stick a small flat head in the small hole at the bottom to pop it down
avstar26
Apr 22, 2009 10:28 AM
themurrell
Feb 21, 2007 08:32 PM
crxforum
Jan 16, 2004 03:59 AM
verseone
Sep 11, 2003 07:41 AM
*Boostwerks*
Sep 13, 2002 08:52 AM
