which arp head studs to use??
So I have a B16a3 bottom end that im gonna slap a brand new itr head on.. which arp head studs am I suppose to use?? My buddy told me to use the B16 head stud since its a type r head,, but when I check ebay,, the B18c5 engine is calling for gsr head studs.... can anyone chime in??? and if possible,, can you give me the part number on the arp head studs?? I have a set for the gsr engine, part number 208-4303 dunno if this is gonna work or not..
Your right gsr are longer so you need to use the B16 ones
But gsr will work on itr..same part # from Honda for head studs. And I have gsr arp head studs in my B18C5
Everytime one of these threads comes up, there all always different answers and proof, I've seen websites selling b16 and type-r studs as the same and GSR seperately, and other websites selling them all as the same, and so forth.
Well then he wouldn't want the b16 one's if he is using a type-r head right? He would want type-r/gsr studs.
Get the studs based on which head you have. PR3 casting heads, get the "B16" ones, and P72 casting heads, get the "GSR" ones. I have had ZERO problems with building multiple B-series using that guide.
b16-b16 studs
b18/20 - ls/b20 studs
gsr/lsv/b20v/any other crazy combo you have - gsr studs
If you have a gsr set they are probably just longer than b16 but might work. Give them a test fit.
I am currently using the studs from my b16a on my sleeved b18a1 block. They will all work but you should be using it based on the block. They are different lengths but nothing that should cause any issues. I have had zero issues and are on my 4th time re-torquing them. i will be changing them next time beacuse they've been torqued numerous times, not casue there for the b16 tho. Hopefully i wont need to be torquing them anytime soon tho. Fingers crossed
If it's based on the block, how come for LSVTEC's you use the studs for the head you have?? And I know LS studs have two longer studs in the middle.
Cause My original build was a built b16a...When that **** the bed on the dyno with No2 i Sleeved a b18a1 block and went FI. It wasnt nessacary to buy another set of ARP's so i kept the b16a's...They worked just fine
honestly I've seen b16 ones on lsvtecs with no issues but they are shorter
But I'm saying, if you get studs based on the block, why are ls/b20v's based off the head?
You would figure that, say, a gsr block with b16 head would used b16 studs. Hence the name "head"studs lol. I'm not disagreeing with you guys, just saying, it's weird.
i see youre logic... Either way there pretty universal accross b series...a few mm difference is only going to be another Turn on the nut of the stud...wow that doesnt sound right lol
because on an ls head where the two center studs bolt up is in a raised section. the two middle studs are longer.
omg,, so many mixed response,, dont know who to listen to... lol this is kinda critical for me cause I want to do it right the first time.. my B16 block has forged pistons and rods and new bearings in them and im gonna be boosting this set up.. so 9000rpm + 18psi = no room for mistake,, lol I dont want to take it all apart again and re-do it..
