rear passenger upper control arm
Old Mar 1, 2012 | 04:30 AM
tommyNhisCivic's Avatar
Icon2 rear passenger upper control arm
Ok so I'm having a major issue. I have eibach proline lowering springs, spc rear lower control arms, myb gr2 struts, front and rear eBay camber kit. Toe is way out I need have it fixed. But my issue is in my rear camber kit. In two months I've had to replace my upper rear control arm twice. Keeps eating up the bushings. Yet driver side is fine. Any ideas what's going on? I'm tired of buying rear camber kits
Old Mar 1, 2012 | 05:09 AM
grumblemarc's Avatar
The Grumpiest
Default Re: rear passenger upper control arm
Ebay? That is issue number one! How can you look yourself in the face after installing Ebay knock-off product alongside something like SPC?
GR2 shocks and lowered? Issue number 2.
Possibly you are not installing it correctly but more than likely it's because you cheaped out and used crap on your suspension. Torquing the bolts in the bushings while the car is up in the air and tires are hanging down is a no-no.
Old Mar 1, 2012 | 08:00 AM
NVturbo's Avatar
O.G. triple O.G.
if you wanted a better brand of camber kit besides ebay "no-name" brand, I would suggest looking into "Wicked Tuning". Don't bother with BLOX because that was what I replaced due to bushing failure/detoriation.
Old Mar 1, 2012 | 08:47 AM
98civdx's Avatar
Master Detailer
You're wondering why that peice of **** camber isn't lasting?!
Stop being cheap.
With the pro kit, you don't even need a camber kit!
Old Mar 1, 2012 | 11:35 AM
NVturbo's Avatar
O.G. triple O.G.
Stop being cheap.
Some people actually like the cambered look......with stock offset wheels. Ricey but that's them. LOL
Old Mar 1, 2012 | 11:38 AM
98civdx's Avatar
Master Detailer
I don't mind my mild camber. -2* all around. But it looked goofy as **** with -3* and my +55's.
Spacers are next.
Old Mar 9, 2012 | 08:46 AM
Actually yes I did need the camber kit, wouldn't bought it otherwise. I thought was cheap kit but only onr side goes bad. I'll order the hard racing rear camber kit
Old Mar 9, 2012 | 08:47 AM
Thanks guys and grumble I did tighten the kit while in the air, so could be another issue. Definitely appreciate the input.
Old Mar 9, 2012 | 08:54 AM
Oh and yea I knew better than to go cheap but my other car crapped out and I needed something fast, couldnt afford good **** lol
neoteny
10
Jan 10, 2015 04:58 PM
beana
Jan 4, 2010 02:08 PM
thumper64
Suspension & Brakes
Nov 10, 2009 07:13 AM
chestnut_55
Jan 2, 2006 10:04 AM
barry11j
May 16, 2004 08:46 AM
