F&F type two coilovers
Im planning on getting into autox, cause my dad used to do it in his subaru. And I was wondering if anyone has used that suspension setup before. How did they perform? Thanks in advance
they will keep your car off the ground.....
if your just starting out, you honestly won't know the difference between good dampers and bad ones. just run the car the way it is and learn how to drive before u start modding into a class that is hard to keep up in because of the prep level.
well i havent messed with the suspension in my crx, and its not stock. it sits low enough to have my pinky fit between the wheel and fenders all around. bought it like that. they are cut springs... so i figured i need to upgrade my suspension.
edit: i exaggerated a little to much. its about 3/4 of space between the tire, with cut springs. but come on.. cut springs??
lol i would if i could, springs or coilovers are one of the many things that needs to be done. i have a 88 crx si chassis, literally nothing but metal(no wire, absolutely nothing) im just making a list of things to be done/bought. i gotta big project ahead of me.
josh combs
Sep 10, 2007 12:24 PM
What they both said before me.
