What hasport Bushing insert should i go with?
Old Feb 29, 2012 | 08:07 AM
AllShowNoGo727's Avatar
Default What hasport Bushing insert should i go with?
Well I took off my mount and checked the inserts, They are the U62A bushing. Im running a ls vtec turbo setup and I think these bushings are worn out causing my avid solid torque mounts to be the only thing supporting my motor on the drives side. I have a nasty vibration ONLY at 3k RPM and its annoying. I am thinking I want to replace these hasport bushing with a stronger durometer. What ones are you guys running and how bad is the vibration. I see they sell 62A(street) 70A (race) 88A (extreme race) and 94A (most extreme Race). Im wondering what will be best for my car 450 hp pump 600hp c16 I drive it on the street a fair amount and my goal for the track currently is a mid 10.
Old Feb 29, 2012 | 12:25 PM
Hasport's Avatar
Default Re: What hasport Bushing insert should i go with?
to keep you engine in place 88a
if you are worried about vibration from street driving then go with 70a
Old Feb 29, 2012 | 01:17 PM
TurboFocus's Avatar
Derka went with the 88a also chris
Old Feb 29, 2012 | 01:39 PM
DA 4 Lyfe's Avatar
I have the 70a and it does vibrate pretty good for a street car. You get useto it though. I wouldnt reccomend anything higher unless its a 100% drag car
Old Mar 1, 2012 | 02:30 PM
b00stin93's Avatar
I had the 62A and the 88A with the Avid torque mounts and couldn't tell a difference in vibration, with the Avids it seemed to not matter. so i would just get the 94A or solid, depends how hardcore you are.
Old Mar 11, 2012 | 06:10 AM
Trunks1331's Avatar
i just installed 5pc. mount kit what i was told were 62a shipped directly from avid, car shook as if they were solid mounts. im not too sure about their durometer rating
Old Mar 11, 2012 | 02:59 PM
.adam.'s Avatar
ive had solid mounts in my car for years and dont have any problems with vibrations.... food for thought
Old Mar 11, 2012 | 04:01 PM
mikesrex's Avatar
I run solid metal mounts
Old Mar 11, 2012 | 04:38 PM
Trunks1331's Avatar
Running a stock motor for now, replaced with oe bushings vibrations are gone
Old Mar 29, 2012 | 10:14 PM
03yzfr6's Avatar
how can you tell what durometer you have? i just picked up a set of hasport mounts second and not sure what i have. thanks....dont mean to sound like a noob.
Old Mar 30, 2012 | 11:21 AM
locash's Avatar
If you press the pin out of the center of the mount, you can pull the bushing halves out. On the inside of the bushing, it will have the durometer number molded into it..
06sik20z3
19
Oct 10, 2012 12:32 PM
dev203d
Mar 1, 2011 11:44 AM
C1CRX
10
Jun 13, 2006 11:08 AM
jsull.
Jun 21, 2005 04:58 AM
jsull.
Jun 20, 2005 05:29 PM
