Mid-Atlantic (Sales) VA, DC, and MD
Civic Integra Del Sol B16 B18C GSR SI Parts *CHEAP*
Old Feb 29, 2012 | 06:59 AM
ProjectEGSiR's Avatar
Default Civic Integra Del Sol B16 B18C GSR SI Parts *CHEAP*
I have receipts for mostly all these b16 engine parts and if you are interested I can include in the sale of ANY Item below.
text me for pictures, two40-605-397five
TEIN basic coilover suspension for EG/DC - $600
Comes assembles with top hats and Front EG forks
Used for 3k miles and then removed from vehicle
Excellent condition!!!
96 GSR OBD2 Cylinder Head - $180 obo
Valve Damage and will need machine shop work.
Includes GSR OEM Intake Manifold, Cam Caps, LMA's,
rocker shafts & arms & Head Studs.
94 Integra GSR Fat Five Rims - $200
Good condition, need tires.
B18 LS Throttle Body - $50
96 GSR B18c Cams - $100
B16 ARP Headstuds - $100 obo.
B series Clutch Kit - $80
USED ITR Pressure plate w/ Exedy Street Disc
Fidanza Lightened Flywheel - $80 obo.
B16 Block Rotating Assembly - $400 obo.
Includes: JDM CTR Pistons on B16 Rods with ARP Rod Bolts,
OEM Honda B16 Crank, OEM Honda Crank and Rod Bearings
all in perfect condition. Block was milled to low by machine
shop and leaks at the head gasket so parting out internals.
Was only used for 6k Miles.
B16 / LS Block Girdle conversion kit - $150
Includes: GSR/ITR style Block girdle & OEM ITR Crank cap bolts(x6)
This kit will bolt up directly to ANY B16 or LS Motor without Modification
and greatly strengthen your bottom end and allow higher reving.
ITR B18C OEM Oil Windage Tray -$40
ITR B18C OEM Oil Pick-up - $40
ITR B18C P72 Oil pan - $80
SKUNK2 Front Civic Integra Camber Kit(One side needs new ball joint)pair - $50
94-01 Integra GSR B18C1 OEM Intake Manifold w/ Gaskets(BARE) - $40 obo
92-95 Civic GREY Steering Wheel & Air Bag - $20
92-95 Civic SI Seats Charcoal - $100
92-95 Civic / 94-01 Integra Black Steering Wheel & Air Bag- $40
B16/B18/B20 Hydro Transmission(Clutch Housing ONLY) case *BARE*- $30 obo
B16/B18/B20 Hydro Transmission case *BARE*- $80
B16/B18/B20 OEM Flywheel bolts(USED) - $15
OEM B16 Oil Pan w/ Password JDM Baffle - $90 obo
OEM B16A VALVES - $30
OEM B16 (Lost Motion Assemblies) LMA's - $30 obo
NEW B16 aftermarket Timing Belt - $30
OEM Integra GSR B18C Intake Valves - $20
Picture available upon request
Located in the Aspen Hill Area 20853 for pick up
Shipping available and Paypal verified Business User
Text me @ Two40-605-397FIVE
Old Mar 2, 2012 | 12:34 PM
Default Re: Civic Integra Del Sol B16 B18C GSR SI Parts *CHEAP*
Will trade for;
- B Series lightened Flywheel
- B16 DC Sport 4-2-1 Used Headers
- Chipped p28 or P72 Ecu
Old Mar 3, 2012 | 06:47 AM
Old Mar 5, 2012 | 08:35 AM
Bump
Old Mar 7, 2012 | 07:21 AM
Bump
Old Mar 19, 2012 | 08:21 AM
by some of this!
Old Apr 11, 2012 | 05:16 AM
rudebwoy's Avatar
if the headlights are OEM not ebay I will take them with these, please post some pics.
93-97 Del Sol Headlights USED(Pair) - $25
93-97 Del Sol OEM Corner Lens(Pair) - $15
93-97 Del Sol OEM Fog Lights(Pair) - $40
Old Apr 11, 2012 | 07:12 AM
los02's Avatar
Are these off of a OEM Del Sol VTEC with the B16 or the S and Si models?
93-97 Del Sol Front Knuckles/Spindles w/ Calipers, Rotors, Pads (PAIR) - $50
If they are off of the factory Del Sol VTEC (B16) then I am interested.
Old Apr 13, 2012 | 05:45 AM
They are from the RED Del Sol you sold me with the leaking roof that you said it didn't have. SI w/ D16. Text me if your interested.
Old Apr 14, 2012 | 11:34 AM
rudebwoy's Avatar
I'm still trying to buy those del sol head lights
Old May 3, 2012 | 08:18 AM
BUMP
Old Sep 12, 2012 | 08:12 AM
Bump
Old Oct 3, 2012 | 07:18 AM
Bump
Old Oct 9, 2012 | 06:22 AM
Bump
Old Nov 20, 2012 | 06:47 AM
Bump!
Old Nov 29, 2012 | 06:27 AM
BUMP
Old Nov 30, 2012 | 08:42 AM
bump
Old Nov 1, 2013 | 10:44 AM
BUMP
Old Nov 7, 2013 | 06:14 AM
BUMP
Old Nov 15, 2013 | 06:07 AM
BUMP
Old Nov 26, 2013 | 06:14 AM
bump
Old Dec 12, 2013 | 08:20 AM
Old Jan 7, 2014 | 12:24 PM
2014
Old Jan 10, 2014 | 08:35 AM
bump
Old Jan 14, 2014 | 07:01 PM
jdmpoweredsol419's Avatar
Location? Do you have the keepers with the b16 valves?
