B-series swap last check list
Old Feb 28, 2012 | 11:08 PM
lilbinky's Avatar
Default B-series swap last check list
I am finishing up a b-series swap in a 1996 Civic hatch tomorrow and I was going over my list of things to make sure are done before cranking...
Help me out honda-tech to amke sure I am not forgeting anything!
P.S. this is not in any specific order.
-Coolant hoses and clamps
-Vacuum lines
-fuel line
-put intake on
-install header with o2 sensor
-tranny fluid, oil, and coolant
-clutch line install and bleed
-Tighten down a/c compressor bolts
-throw battery back in
-install belts (not sure why I didn't do this while the motor was out) LOL
Hopefully once it is up and running I can shoot some pictures and post them up.
Motor-
96-97 Spec ITR motor w/ LSD tranny
Innovative billet mounts
new clutch (daiken street disc and pressure plate)
Hytec Rep. header
HKS hiPower Exhaust
PWJDM Power chamber intake
New axles
ITR shift linkage w/ urethane bushings and Buddy Club shifter
Very MILD wire tuck/managment job
Slim fans
New radiator (replace the one I broke like a jack ***)
Car-
1996 Honda Civic Hatchback
CTR rep. spoiler
CTR rep. lip
Bronze wheels
KYB GR2's w/ Tien s-tech springs
I am building this car for a friend, I am not a huge fan of some little things, but I am overall happy with the outcome of the build so far. Plus we retained a/c and that excites me. It used to be the cool thing to ****** all that crap out, but times have changed!!!
Pics to come
Old Feb 29, 2012 | 05:44 AM
DelSol-B18's Avatar
Default Re: B-series swap last check list
Connect ground wires. Duh!!! Lol
Old Feb 29, 2012 | 06:18 AM
Deetz's Avatar
Crazy Honda Guy
You have forgotten.....
- EM1 engine post mount
- EM1 rear tranny bracket
- new throttle cable
Old Feb 29, 2012 | 06:57 AM
flmzero13's Avatar
correct me if im wrong cuz i am doing a LS swap on my 4dr.....i know you need the t bracket from a SI but can you use your ls one or the single cam one cuz my boy said u can but its going to be retarded and not the proper way its like a last resort option....will it work?
Old Feb 29, 2012 | 08:16 AM
DelSol-B18's Avatar
D series one, NO and what year is your car? 92-95 get the del sol vtec one/b series eg. If its 96-00 you need b series si one
Old Feb 29, 2012 | 08:27 AM
JuggerNaut-CTR's Avatar
I dont see anything about harness...ecu...how vtec is going to activate???
Old Feb 29, 2012 | 11:44 AM
flmzero13's Avatar
i got a 97 four door and what ur saying if i dont have a 2post mount from a em1 my swap is uselles?
Old Feb 29, 2012 | 01:47 PM
lilbinky's Avatar
The motor is bolted in the car. I have already swapped the post, changed clutch, rear tranny bracket, and performed all ECU pin outs.
I just wanted to see what I may have missed. These are the kind of responses I was looking for. I kind of left out details on how far I was in the process so I could basically say "yes or no" when some body made a suggestion!
Thanks so far guys and keep it coming.
soon2bdropped
Jun 25, 2007 01:18 PM
toguemaster
Feb 10, 2007 02:06 PM
spyz34
Nov 18, 2004 11:19 AM
hondaless
May 1, 2003 09:40 AM
pub
Oct 24, 2001 02:05 PM
