Prelude Fogs question....
I got some prelude fogs for my EF, I wanna throw some 5k hids...the question is, will the hid bulbs fit since it has the capsule? And if they do fit, will the hids burn through the capsule?
I opened mine and removed the cap and square plate. The H3 hids do not fit with the caps. 5k low beam, 3k in Prelude fogs on my hatch, I light up everything lol.
You might be making custom brackets, go to lowes get some steel brackets and do some bending, its really not that hard, take some time. I was lucky with mine, installed on a WW front bumper and just had to drill a hole above and inside the bumper I put some metal brackets to support the weight with a bolt
^^^^you did that you fakin liar I did all the work while you laid in the couch bish………but yeah just cut the lip of the bumper support and drill a hole and just use the stock brakets ……also I got h3 hids on my fogs they fit fine but I kept the capsule so I recomend using the 3k color if not they will look different color not yellow
