Suspension & Brakes Theory, alignment, spring rates....
squishy brake pedal?
Old Feb 28, 2012 | 04:19 PM
98integralsB18's Avatar
Default squishy brake pedal?
Hey guys, I have a 94 integra that I did a brake line tuck in and I am having a squishy brake pedal. If I press on it hard (or have to stop quickly) its fine, say if I am going down a hill and just press on it lightly it will gradually go to the floor. I have bleed my brakes multiple times. I have no leaks and its brand new fluid. Would this be my brake booster or master cylinder?
Thanks
https://honda-tech.com/forums/showth...=integra+build
Old Feb 28, 2012 | 04:41 PM
bukolkol's Avatar
Default Re: squishy brake pedal?
are you losing any brake fluid. master cylinder could possibly leaking internal, to test it start clamping brake hose one at a time to see if brake pedal does go down.
Old Feb 28, 2012 | 05:21 PM
the brakebooster was wet at one point, but i had a washer on the one stud side and not the other. so i took it off and i dont think it leaks anymore. maybe ill just get a new master before i go and get a new brake booster and no no brakes lines leak.
Old Mar 5, 2012 | 12:50 PM
anyone else have any input?
thanks.
Old Mar 7, 2012 | 06:48 PM
Andres01's Avatar
Bro i have the same problem but it only happens whenever am about to drive my car in the morning ... I have to pump on the brake pedal for the car to actually get brakes. I changed the master cylinder, bleed the lines and it still didnt get fixed.
SMH
Old Mar 7, 2012 | 11:19 PM
seanbev24's Avatar
A washer on 1 side won't have anything to do with a fluid leak. The only place fluid should get in/out is the reservoir cap. A lot of times people don't notice a leaking MC because the fluid just pools inside the booster. The slowly sinking pedal, if you're sure there's no air in the lines, sounds like a bad MC (fluid bypassing the seals internally).
Old Mar 8, 2012 | 10:17 AM
Okay, I will try to replace the MC and let you guys know.
stevescivic
13
Apr 14, 2014 02:23 PM
hteg12
Jul 18, 2013 05:13 PM
kelviiv
Jan 9, 2011 11:31 AM
Markb16a
11
Aug 26, 2010 09:12 AM
NuclearB18B
Jul 5, 2005 07:21 AM
