Saenz F/H22-23 STraightcut synchroed gearset
Old Feb 27, 2012 | 08:14 PM
extralargenog's Avatar
Default Saenz F/H22-23 STraightcut synchroed gearset
Hello guys!
As of TODAY 2/27/2012
Unfortunately, Its just not feasible to do the Albins set right now, Ive talked to James and we both agree.... at this point the turnaround is just too far out for a number of us AND the exchange rate is upside down. Getting 5 people together with 2k AU (Closer to 2200 US and getting worse-non refundable) deposit has proven to be rough with timing... also there is NO gaurantee that the rate wont get WORSE for the final payment....
In light of this, I have been talking to Gabriel at Saenz in Argentina and they have H22 sets ready to go, and after shmoozing....Ive got a good deal going through their US distributor. The deal is for 3 sets (I have 2 guys so far) He will do 2850 + ship per set.
Included is the forged Input shaft, forged straightcut syncro engaged 1-5 gearsets and special split bearing the set uses on the Input shaft. Its a a drop in solution. This is with all of the upgraded gears and whatnot as well (I had run one of their older prototype sets, and after having upgraded the set with the newer 3 and 4 It worked great at 700-750 WHP), never broke it after the upgrades.
The set uses H or F series 1 and 2nd gear syncros, sleeves, springs and hubs. OEM or carbon, both completely compatible. I had great luck with both....3-4 uses a H23/F22 Syncro set (The synchro dogs on the gearare the 50,mm F series or H23 style), slider, hub ,springs and fork (they are smaller than the H22 stuff)... 5/R uses either H or F 5/R hub, sleeve springs and fork....
That means you can use a set of F forks and sliders. H23 forks and sliders, or Go with a H22 1/2 and 5/R set of forks and use just the F or H23 3-4 fork...
The set uses ANY H22 final drive. OEM or aftermarket. It is a drop in deal. Assemble with your sleeves syncros hubs etc, check for MS endplay... Shim accordinly and youre good to go.
The gears are short, but MAN does the box make a difference in acceleration (AND HOLD UP TO ABUSE). A car I usually was side by side with at 500 WHP on a M2Y4 tranny... I put the Saenz set in it and I would get out 2-3 cars. I run 26" tires and will be using a 4:1 final. Last time around I was using a OEM 4.26 FD. Even with the 25.4" 235/60-15 M&H it was a bit short (Like a B216 tranny LOL), but I liked it. Im running a G-20 M&H now so its a true 26.1" tire and the 4:1 FD will help a good bit.
If this is confusing I can explain it further in detail.... Feel free to PM me (with your phone number please)
Gear ratios are 3.071 1st, 2.153 2nd, 1.667 3rd, 1.30 4th and 1.0 5th. I used Redline lightweight shockproof fluid in mine with great results. Torco RTF would be another great option. I dont suggest using anything else. I had ABSOLUTELY ZERO issues with any shifting (IT SHIFTED LIKE BUTTER EVEN THE 4-5 SHIFT flat footed at 9K using the LWSP with OEM or Carbon Syncros.... Even when cold, there were no problems The box always shifted flawlessly. All bearings looked good using it and never had any kind of heat looking like it went through it and Id drive the car for HOURS at a time on the street regularly
Looks like this (This is the old Prototype I had that I beat on for years)
Im confident in the Saenz set and want another one in my car. NOW... We need ONE MORE GUY . If you're interested in Blabbing, PM me. Looking to do this in the next 2-3 weeks, As mentioned myself and another are good to go and have cash NOW.... Tax time is here... Spend your money :O). I need a set in my car NOW, and this is a far better and stronger option than the Mfactory set available. From experience. Ive almost got a friend of mine thats already Broke the Mfactory set at 550 Wheel to sell it and get in on this, IF he does, its all we need and its a done deal.
Full amount of sets will be paid to Saenz, then upon Receipt of hardware by Saenz USA.... They will work out our individual shipping details and We are IN BUSINESS!!!!
Nice thing is they have parts available on the shelf as well should anything happen and you don't have to wait months... When I did need something the US guys were awesome , I had it in 2 weeks.
AS SOON AS WE GET 1 MORE GUY WERE DOING THIS....
Old Feb 29, 2012 | 01:28 AM
Default re: Saenz F/H22-23 STraightcut synchroed gearset
Need 1 more!!!!
Old Feb 29, 2012 | 02:20 PM
eg6-jarhead's Avatar
wish i had the $!
Old Feb 29, 2012 | 08:39 PM
BUMP AGAIN CMON ONE MORE!!!!!!!
Old Mar 1, 2012 | 11:41 AM
Got them sold. Thanks.
Old Apr 18, 2012 | 07:05 AM
h-duced's Avatar
Can I get in on this? Or is it too late?
Old Apr 18, 2012 | 08:18 AM
Oll have to check. Ill hit you up via PM I got yout PM. Yours if doable definately wont be on this shiopment, youll have to wait but Ill see what I can do.
Old Apr 18, 2012 | 10:32 AM
ESP.net's Avatar
PM me back, have some turbo talk to do!
Old Apr 18, 2012 | 11:41 AM
call me tonight, tis the best way sir... I ****ing hate texting :O)
Old Apr 20, 2012 | 07:06 AM
builthatch's Avatar
MiG-21 superfan
h-t doesn't allow group buys. sorry guize.
Old Apr 1, 2020 | 10:19 PM
Default Re: Saenz F/H22-23 STraightcut synchroed gearset
THx Clayton for fixing the thread and bringing it back. It has usefull information t the guys running the set, I sold and installed probably 30 of them.
Old Apr 1, 2020 | 10:21 PM
**** wrong thread or all the info was hogged out of it
Old Aug 28, 2020 | 06:34 PM
speedworks's Avatar
can you get or have one of these sets available?
extralargenog
Transmission & Drivetrain
Mar 1, 2012 06:34 AM
luder916
Honda S2000
Jan 18, 2011 05:30 PM
chiboy002
Jan 16, 2010 10:47 AM
MattZ28
May 3, 2007 11:07 AM
FUEGS
Apr 7, 2007 04:58 PM
