REAL hydro conversion ??
Old Feb 27, 2012 | 08:08 PM
mr darcko's Avatar
Default REAL hydro conversion ??
I don't want to use the hasport mounts, me and my car are in it for the long run so i wan a more permanent transfer, those mounts are big ugly and soften the pedal to much. I know i'll need to drill my firewall out for a clutch master cylinder and then i'll need to run the lines, my question is will i need an eg pedal assembly as well? or will it hook to my current pedal? i haven't had to change the current clutch cable so i have no real reason to take a look under there and see if they are the same. any info on this would be awesome.
Old Feb 27, 2012 | 08:57 PM
Stunna MIKE's Avatar
Default Re: REAL hydro conversion ??
you want something like the suja or hush22 kit ? or use the hydro pedal and all that jive ?
Old Feb 27, 2012 | 08:59 PM
mr darcko's Avatar
yeah basically, but i dont understand why that kit is necessary, cant i just bolt up the clutch cylinder to the firewall and hook it up to my current pedal?
mr darcko's Avatar
or use an eg clutch pedal assembly? not the whole thing just the clutch pedal.
Old Feb 27, 2012 | 10:52 PM
redsolturbo's Avatar
go read my thread it lists everything that needs doing (though mine is RHD not a left hooker)
principal is the same:
http://board.hondacrx.co.uk/phpBB2/v...c.php?t=118929
Old Feb 27, 2012 | 11:01 PM
oh a mini version of my build is also on here
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/my-vtec-half-way-done-2966806/
Old Feb 28, 2012 | 05:37 AM
judgeDredd's Avatar
hush 22 kit they are also developing a RHD version
http://www.facebook.com/pages/Hush-P...65426303519234
th3pwn3r
Transmission & Drivetrain
10
Oct 4, 2011 12:05 PM
Clipsed
Dec 9, 2008 11:33 AM
brian g
Mar 31, 2008 08:17 AM
silverskateEF9
Feb 21, 2008 11:45 PM
Sliced Beard
Feb 6, 2004 09:34 AM
