B18C EG1 swap parts list check
Old Feb 27, 2012 | 07:13 PM
MadCoder's Avatar
Icon6 B18C EG1 swap parts list check
Wanted to post this up to hopefully save someone time of searching for part #'s if your doing a B18C swap in your Del Sol.
This list doesn't include shift linkage, ecu, axels, etc.
Let me know what everyone thinks and if I'm missing anything crucial.
OEM PARTS
GASKET SET, HEAD COVER
Product ID: 12030-P30-000-Acura
WATER PUMP (YAMADA)
Product ID: 19200-P72-013-Acura
BELT, TIMING (126RU26)
Product ID: 14400-P72-014-Acura
TENSIONER, TIMING BELT (KOYO SEIKO)
Product ID: 14510-P30-003-Acura
HOSE, WATER (UPPER)
Product ID: 19501-P08-000-Honda
HOSE, WATER (LOWER)
Product ID: 19502-P08-000-Honda
OIL SEAL (38X50X7.4) (NOK) (Front main seal)
91212-PR3-003
OIL SEAL (80X100X10) (NOK) (Rear main seal)
91214-PLE-003
ROD, CHANGE (shift linkage)
54201-SR2-G03
EXTENSION, CHANGE (shift linkage)
54301-SR2-G01
AFTERMARKET PARTS
Exedy Stage 1 Organic Clutch Kit
08800B
NGK Iridium IX
BKR6EIX-11
NGK Wires
HE64
Old Feb 28, 2012 | 01:37 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: B18C EG1 swap parts list check
Not crucial but what about cam seals, cap and rotor?
Old Feb 29, 2012 | 06:39 AM
MadCoder's Avatar
Trying to keep cost relatively low so only changing out timing belt, water pump, clutch and plugs while engine is out.
Rest is really required to do the swap.
Old Feb 29, 2012 | 08:25 AM
NVturbo's Avatar
O.G. triple O.G.
shift linkage.....from a DOHC VTEC Del Sol:
http://www.oemacuraparts.com/find-pa.../SHIFT%20LEVER
Your stock Del Sol unit WON'T WORK....neither will the GSR.
Old Feb 29, 2012 | 12:05 PM
MadCoder's Avatar
Good call.
I got mine like 6 months before the engine so I completely forgot about it.
umskittles
Aug 18, 2012 06:18 PM
loverboy
May 6, 2007 04:18 PM
crsexmex
Mar 6, 2005 09:03 PM
eg6hatch
Mar 9, 2003 01:53 PM
Monty
Aug 31, 2002 12:21 PM
