Cleaning JDM SiR gauge faces?
Old Feb 27, 2012 | 03:47 PM
K20egcw's Avatar
Default Cleaning JDM SiR gauge faces?
I recently got a JDM SiR gauge cluster, and I took the bezel off to try to swap a USDM one on there (thought they were interchangeable) because the cluster I gave him had a crack. Anyways, while the bezel was off I touched the white part of the gauges and now there are a couple little grease smudges on the faces. Is there a good way to clean them without messing up the white part, or just anything in general? Thanks!
Old Feb 27, 2012 | 04:51 PM
MRGRIM's Avatar
R.I.P. Mark
Default Re: Cleaning JDM SiR gauge faces?
the gauge face print is tough
just use dishwashing soap in warm water
I had to do this when i got a cluster from Japan
it had little asain greasy finger prints all over it inside and out
use a soft cloth on your finger tip JUST WIPE DONT RUB
be careful of the needles and needle stops
once the mark in gone wipe all faces or you will have a clean sopt
Old Feb 27, 2012 | 05:08 PM
K20egcw's Avatar
Cool, that's what I was thinking. I'll go give that a try. Thanks
89hatchback
Feb 17, 2004 05:40 AM
allmotr1.8
Oct 27, 2002 07:03 PM
