SUSPENSION
Old Feb 27, 2012 | 02:43 PM
William1991b's Avatar
Default SUSPENSION
Is my tie rod end bad? Do i need to replace that ball joint?
Do you see anything bad? I hear a squeak sound when going over bump or uneven roads.
http://www.youtube.com/watch?v=-D463H4Ie28
Old Feb 27, 2012 | 03:08 PM
jdowen2's Avatar
Default Re: SUSPENSION
Your tie rod end looks a little loose. Can you move the tire (car on jack stands) when you grab at 3 o'clock and 9 o'clock? Those sway bar end links looks really short.
Old Feb 27, 2012 | 03:24 PM
I can move it a little. But it the same as my right n I dnt hear a sound. What do u mean about sway bar to small? I tightened it to much or the bolt looks small?
Old Feb 28, 2012 | 06:50 AM
snyds's Avatar
I'm having the same issue on my 93 accord. I've replaced shocks, lower ball joints, upper control arm, tie rod end, sway bar bushings. Still have the sound.
Old Feb 28, 2012 | 08:42 AM
That what im not trying to do replace all the part and i dont get the squeaking sound fixed. Might be lower control arm for u. I thought it was that for me but I don't see anything wrong and I greased it up and still squeak but now i greased the upper ball joint now the sound stopped but its only been a day. I might have to replace it but idk if it was just dry or what. Look at the video 1:20 can u tell if the ball joint bad? Sorry that its only a few sec. I might take pictures tonight.
Old Feb 28, 2012 | 06:36 PM
jdowen2's Avatar
Did you replace your stabilizer bar or just the end links. It looks to me like you left out a stabilizer end collar. See ref. number 005 at http://manchestermotorsports.com/index.cfm, chassis section, front lower arm. The sway bar might be rubbing because of this.
muddywj
Feb 1, 2015 12:43 PM
F20BWagon
Suspension & Brakes
Jan 20, 2015 06:23 PM
sl0waccord
Feb 13, 2012 03:43 PM
soon2bdropped
10
Feb 27, 2011 11:26 AM
Milab21
Suspension & Brakes
Jan 27, 2009 06:21 AM
