d16y8 97 del sol decelerating, weird smell
Old Feb 27, 2012 | 01:51 PM
mish__'s Avatar
Default d16y8 97 del sol low acceleration, weird smell
Maybe you guys can help me out, this has never happened to me before so it threw me off.
I have a 97 del sol si (d16y8). I just got off of work earlier and as I was a mile away from my exit, my car started decelerating from 70 to 60 to 40 and my brakes were hard, but my accelerator became really soft. I pressed on it, the engine roared, but barely pushed. My car didn't overheat but it gave off a weird smell. So I tried to pull into the gas station. Once I turned off the car, the car made a weird sound.... like its burning something off. I turned it back on and forced my car to move.... it went down the block to 40 and started to decelerate again. So I pulled off to the side and turned the car off. I start the car up again... drove off... and its fine. Im so confused. Im scared it'll happen again. Has anyone had this experience?
Old Feb 28, 2012 | 01:34 AM
mish__'s Avatar
Default Re: d16y8 97 del sol decelerating, weird smell
Bump
Old Feb 28, 2012 | 09:52 AM
SykoFerret's Avatar
I'd start with ignition and fuel system, my gut says fuel pump, but go over the alternator, battery, etc. to be sure.
I support the claim that keeping over half a tank helps ease the wear on the brushes in the pump motor.
Old Feb 28, 2012 | 10:57 AM
WhiteOnRice's Avatar
Does it smell like clutch? (similar to overheated brakes)
Old Feb 28, 2012 | 12:52 PM
mish__'s Avatar
Gas was full.
I think my brothers beamers fuel pump went out before, so I don't think that was it
because I explained the story to him and he was puzzled.
Old Feb 28, 2012 | 12:53 PM
mish__'s Avatar
It smelled toasty.
opening the hood, I couldn't see what was wrong.
It just had this nasty toasty smell.
Old Feb 28, 2012 | 05:28 PM
mish__'s Avatar
Update: car drives fine now... low clutch master cylinder fluid... no leaks under clutch pedal. Clutch pedal is normal. Any ideas?
splashy
Sep 10, 2017 08:48 AM
aux102
May 31, 2013 08:12 AM
Civic2Fast
May 5, 2012 06:16 AM
DEL97SOL
Feb 12, 2009 05:03 PM
96ls
Mid-Atlantic (Sales)
Nov 5, 2008 01:17 PM
