SOHC ZC Questions
Old Feb 27, 2012 | 12:17 PM
t-town_ep's Avatar
Default SOHC ZC Questions
So as I've been finding out, a sohc zc non vtec is the same thing as a d16a6. Does this mean that its obd0 as well? are all sohc zc non vtec's obd0?
More important is this sohc zc obd0?
http://www.hmotorsonline.com/shop/sc...age&item=30020
need to swap it into my ef std hatch. just going to run the 4spd tranny.
im aware that i need to do the dpfi-mpfi conversion, but is there anything else?
Lee
Old Feb 27, 2012 | 12:30 PM
jlicrx's Avatar
Default Re: SOHC ZC Questions
not all SOHC non-VTEC ZCs are OBD0 - they came in OBD0, OBD1 and OBD2 - the one pictured in your link is OBD0
Old Feb 27, 2012 | 12:51 PM
t-town_ep's Avatar
is there any way i can tell just by looking at the motor?
Old Feb 27, 2012 | 01:01 PM
jlicrx's Avatar
in stock condition, the OBD0 engines have white (they kind of turn yellow with age) plastic connectors at the distributor and injectors - OBD1 have gray plastic connectors - OBD0 engines have the cooling fan switch on the back of the block next to the oil filter - OBD1 has the switch on the thermostat housing - OBD0 uses a 3 rib alternator belt - OBD1 uses a 4 rib belt
some OBD0 and OBD1 SOHC non-VTEC ZCs came with dual carbs
OBD2 SOHC non-VTEC ZCs have the spark plugs at the front side of the valve cover - some look like a D16Y7 and some look like a D16Y7 with a D16Y8 intake manifold
Old Feb 27, 2012 | 01:10 PM
jlicrx's Avatar
not quite the same thing - ZC is 118hp and D16A6 is 108hp
Old Feb 27, 2012 | 02:06 PM
handicrx's Avatar
that one is OBD-0 if your really unsure call and ask.
good luck getting a single cam from h motors i ordered one and waited weeks while they lied about ordering it, talking about "oh yeah it'll be here next week blah blah blah" 5 weeks in a row with no updates and shitty customer service. eventually just got my money back and found one locally. i also got the feeling while i talked to them that i was a second rate customers because i wasn't dropping thousands. If your looking for a b series they got'em all day, single cams.....not so much
Old Feb 27, 2012 | 06:52 PM
t-town_ep's Avatar
handicrx, thanks for the heads up.
so i should have no problem with this swap then right? if its obd0 then i just do dpfi to mpfi conversion?
and everything should bolt up as if it were the original d15b1 correct? axles trannys and mounts?
t-town_ep's Avatar
also what ecu should i be running?
Old Feb 28, 2012 | 06:08 AM
jlicrx's Avatar
PM6
Chino12
Nov 2, 2015 07:10 PM
Chewy Built !
Apr 26, 2007 08:44 PM
Angry
May 5, 2006 08:58 AM
ZCpwrdEK
Oct 24, 2005 02:48 PM
