94 Del Sol S: starts and idles if throttle held half open
Old Feb 27, 2012 | 11:41 AM
94delsol#37's Avatar
Default 94 Del Sol S: starts and idles if throttle held half open
Ok so i have been building a b18a1 with b16 head the internals in the block are stock crank scat rods n wiseco 81.5 mm 8:1.5 compression with a b16 head stock cams skunk2 pro series intake aem fuel rail n pressure regulator all in a 94 delsol s. Before the build it ran after i did the pistons n rods it starts when i hold the throttle half open n idles if half open i have tried to do my own wire tuck which im going to redo tomake sure thats not it.any other suggests on y it wont run btw chipped p28 ecu is wat its hooked up to.
Old Feb 27, 2012 | 11:47 AM
PsychoRex's Avatar
Default Re: help
Did you set piston number one at TDC & put your timing marks correctly when you installed your timing belt?
Also make sure the rotor inside the distributor is facing number one, when reinstalling it.
Old Feb 27, 2012 | 11:54 AM
grumblemarc's Avatar
The Grumpiest
Default Re: help
What car are we even talking about?
The P28 is chipped for what? The current setup?
Did you set the mechanical and ignition timing?
Old Feb 27, 2012 | 12:16 PM
Sol'd Out's Avatar
Default Re: help
grumble, I believe it is in a 94 Sol S.
Old Feb 27, 2012 | 02:48 PM
Default Re: help
Ya the p28 is part of the setup n ya we messed with the timing alot n plan on alot more when i get back home. is it possible to not have enough compression cuz the piston rings havent seated
Old Feb 27, 2012 | 04:37 PM
Former User's Avatar
Default Re: 94 Del Sol S: starts and idles if throttle held half open
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
89civicb16a1
Mar 8, 2011 07:20 AM
luder916
Aug 8, 2009 09:00 AM
89civicb16a1
May 20, 2006 09:23 PM
sexdrg9
Mar 9, 2006 04:36 PM
chris0324
Oct 24, 2005 07:40 AM
