Door Lock Troubleshooting??
Sup HT,
My 97 accord has doing this weird thing when i lock the car. When I lock it all the doors locke, then the drivers side door locks and unlocks while the rest remain locked. Any suggestions on what causes this and how I can fix it? Thanks!!
It may be the rubber stops inside the door lock actuator. See this thread on accessing:
https://honda-tech.com/forums/honda-accord-1990-2002-2/94-97-accord-d-s-lock-actuator-microswitch-repair-reset-2465699/
have you taken the door panel off recently? what i did when that happened to me is get in and pull the door handle on the inside and hold it out while hitting the lock button
this is bizzare because since I got my 96 it ALWAYS has done that.
I assumed it was normal if the door is open and you hit the switch it is not to lock the drivers door automatically just in case you left your keys in the car.
if the door is closed it works if I sit in the car and hit the switch
adhuot01
Audio / Security / Video
Mar 31, 2008 05:58 PM
Intercooler
Nov 18, 2004 08:43 PM
