Slick size and suspension question
Chassis is a DC2 - I have off the shelf skunk 2 coilovers and tokico illumina 5 way adjustable shocks. I just purchased a set of 24.5/15 slicks. What I need to know is if I crank the coilovers up to get the desired fender to tire clearance and I set the shocks to the 5 setting. Will this be enough to keep from hitting the fender on the slicks when I'm on the brakes at the end or whatnot. Thanks,Adam
I was in the same boat last season...With my koni yellow h&r spring and a shim between top plate and body my slick was hitting my front fender.
With your skunk2 coilovers spring i am pretty sure that everything will be good thought.
I was running a 24.5x8x13 slick with stock ek front fender.
BolivianFuego
Jun 28, 2006 01:10 PM
mrctr
Sep 19, 2004 04:53 PM
