Transmission & Drivetrain Gearboxes, Differentials, Clutches
Loud knocking clunking crunching noises inside trans
Old Feb 26, 2012 | 02:57 AM
portenio78's Avatar
Default Loud knocking clunking crunching noises inside trans
Car drives in every gear and I pulled the axles hoping to find something with no luck. Car has a MFactory LSD. It seems the loudest in 4th and 5th. Something is deffinately coming apart in the case. Any suggestions before I pull the trans out on what to expect?
Old Feb 26, 2012 | 04:11 AM
94EG8's Avatar
Seagull Management
Default Re: Loud knocking clunking crunching noises inside trans
Probably a bad bearing. Pull the transmission and split the case, it should be pretty obvious at that point.
Old Feb 26, 2012 | 05:38 AM
portenio78's Avatar
Noise is worse than bearing noise LoL. Sounds like a "circus" in there with broken and missing parts.
Old Feb 26, 2012 | 08:20 AM
portenio78's Avatar
Update: Had to push the car around in the garage in neutral, and the front wheels will completely lock up!! Start the car and put it in gear, and I can force it to unlock, but with a bog ol "clunk" from the tranny!!
Old Feb 26, 2012 | 11:52 AM
94EG8's Avatar
Seagull Management
Sounds like a bad diff bearing, diff sounds like wobbling around in the case a bit now, if it's locking up and snapping you've probably ruined the final drive at this point, expect to find broken/chipped teeth on the ring and pinion. Expect something that looks like this:
^ that one didn't go bad from a bad diff bearing, I'm pretty sure it was directly related to wheel hop.
Old Feb 26, 2012 | 12:25 PM
portenio78's Avatar
Ya I had some bad wheel hop. The car is stiff, and when it wheel hops, it shakes the **** out of everything for sure.
Jimmy
May 28, 2011 12:53 PM
Rooftop voter
Nov 1, 2010 06:54 PM
Hal9000
17
Jan 12, 2009 08:27 PM
FijiBlueFG2
Honda Civic (2006 - 2015)
Jan 9, 2009 07:03 PM
BudMan
Aug 11, 2004 04:58 AM
