New to the forums but i need help swapping my ls into my crx
Old Feb 25, 2012 | 10:39 PM
randy90crxSi's Avatar
Icon2 New to the forums but i need help swapping my ls into my crx
ok i have a 90 crx si but the guys that i got it off of changed it from obd0 to obd1 so under the hood i currently have obd1 single cam vtec wiring with a p28 ecu.
i recently bought a b18b1 with all obd0 plugs, i have axels, shift linkage, a obd0 engine harness,and a pr6 ecu, a ls hydro tranny , the mounts and the t bracket.
now my question is how can in any way get the wiring ready to drop this in , by changing the plugs or anything , and now how does the clutch line hook up to this tranny? let me know
Old Feb 25, 2012 | 10:45 PM
crx_si-r's Avatar
Default Re: New to the forums but i need help swapping my ls into my crx
first of all what the hell are you talking about?
OBD1 single cam vtec wiring, im assuming your saying you have the harness out of 92-95 civic (Si or EX model) in your car. im not saying it cant be done, but its very tricky to do this the right way.
P28 is for SOHC and not a DOHC, which is what you currently have.
PR6? what they hell is that? did you mean PR4?
if the harness is working fine, leave it be. you dont have to bother with switching any plugs (aside from converting your obd1 o2 sensor to a single wire). all plugs will plug into their respective sensors.
Old Feb 25, 2012 | 11:00 PM
ok yea my ecu i have for the ls is a pr4. what would i need to do to make this work with the wiring in have currently, and if i need to do any wire splicing i have a obd0 engine harness to take the plugs from
Old Feb 25, 2012 | 11:04 PM
crx_si-r's Avatar
if your car is running fine with the harness you have now, leave it alone. you wont have to do any splicing. you will just have a few extra wires/sensors left over.
Old Feb 25, 2012 | 11:15 PM
alright so ill keep the wiring how it is because i do not want to try the wiring nitemare. now how would i make the obd0 ready for my wiring?
Old Feb 25, 2012 | 11:21 PM
crx_si-r's Avatar
as long as you have an obd0 ecu, distributor and o2 sensor your set. you will of course need to modify your distributor plugs to match the obd0 distributor. your ecu portion, im assuming an ecu jumper was used, will just plug in. it would be easier for us to tell what your working with if you posted some pictures.
make the obd0 ls ready for my wiring
Old Feb 25, 2012 | 11:22 PM
alright thanks ill post pics soon like tomorrow when i have some light
Old Feb 26, 2012 | 04:30 AM
crvtectim's Avatar
In for pics...
Old Feb 26, 2012 | 06:48 AM
stackedhouse's Avatar
Are you converting back to obd0?
Old Feb 26, 2012 | 07:48 AM
no i cant convert back to obd0 because i cant do it myself and i dont have the funds to pay for a shop to do it
Old Feb 26, 2012 | 08:08 AM
crx_si-r's Avatar
converting backwards is fairly simple, depending of course on the condition of your harness and what was done to it.
Old Feb 26, 2012 | 08:26 AM
It's hard to take pics of my problem but check this out I took it to the shop by me and had there master wiring guy look at it and he said what it looks like is they used obd2 wirin and changed all then ends to obd1 an plugged it right in
Old Feb 26, 2012 | 09:39 AM
crx_si-r's Avatar
Master wiring guy? I don't think he knows what he is talking about. Obd2 wiring harnesses are completely different than obd1, already for a civic.
Tell you what, txt me some pics n I'll see if I can help
916-541-5266
Old Feb 26, 2012 | 12:56 PM
allright ill hit you up with some pics i have a 760 number its me
VtecLover262
Aug 22, 2006 11:27 AM
crampinyourstyle
Aug 10, 2006 03:44 PM
CanadaCivic
Aug 13, 2002 03:05 AM
