Russel Stainless steel clutch line install question!
Old Feb 25, 2012 | 08:39 PM
jdmem205's Avatar
Default Russel Stainless steel clutch line install question!
Hey guys since my other thread got deleted for me not following the rules (my bad). I posted this new thread.
My question is the russel line direct bolt on Or do I need to purchase fittings? If I do need to purchase fittings what sizes, shapes etc do I get? thanks for any help
Old Feb 25, 2012 | 10:41 PM
NotAJDMFanBoy's Avatar
Default Re: Russel Stainless steel clutch line install question!
The line should be -3 or -4 and you need either 10mm x 1.0 to the -3 or -4 for the line. If the master cylinder end has a banjo fitting or a just a straight end, you'll need a 10mm x 1.0 banjo bolt or need a 90* banjo to -3 or -4. Adapter screws in first, then the line screws on. Do not use teflon tape on the AN fittings, they seal on the seat, not the threads.
B18c5__Owns
Mar 25, 2009 12:48 PM
prelude72569858
Sep 14, 2008 08:00 PM
