02 RSX Base K20a3 Valve Lash Specs
Old Feb 25, 2012 | 06:54 PM
skiracer8148's Avatar
Default 02 RSX Base K20a3 Valve Lash Specs
Not sure if this is correct but this is what is under the hood but everywhere online im looking is saying different. 2 sets of feeler gauges i own do not even go as low as 0.02 or do i go by the first number
Old Feb 25, 2012 | 07:14 PM
90sedan's Avatar
Default Re: 02 RSX Base K20a3 Valve Lash Specs
You go by the first number. If you look close you will see a (+) and (-) in between the numbers which indicates a range of 0.02mm (+) or (-) from the first number.
So the intake valve lash range is: 0.21-0.25mm
And the exhaust valve lash range is: 0.28-0.32mm
Ideally you would use a feeler gauge in the middle of the range so it's easier to adjust properly without being too loose or too tight.
So try and use a feeler gauge as close to 0.23mm and 0.30mm as you can.
Old Feb 25, 2012 | 09:46 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
^^this...
the second number is a range... plus or minus which gives you some leadway
Old Feb 25, 2012 | 10:26 PM
Thanks so much guys!
Old Feb 29, 2012 | 09:06 AM
ahmad-a's Avatar
Is this hard to do yourself if you only change your oil yourself? If I pay someone to do it what can I expect to pay?
coupon
Dec 1, 2004 11:55 AM
gamakichi77
Jul 28, 2004 09:56 PM
drifto808
Jul 25, 2003 11:37 AM
ponkarse
Jul 13, 2003 09:12 AM
fe519
Mar 22, 2003 08:53 AM
