Good racing harness?
This question has been asked a thousand times, with a thousand different answers. Do a search, or see the faq here:
http://www.soloracer.com/harnessfaq.html
For Autocross, I would recommend the Schroth 3 or 4 pt Harness. A 3 inch wide 5 or 6 pt racing harness is probably overkill for autocross, not too mention quite a bit more expensive.
I've seen several folks using the Schroth harness for auto-x, and they seem to like it.
This is the first link that came up in a google search. http://www.soloracer.com/schroth.html
Takata
overpriced waste of money.
your paying for a name if you get takatas.
simpson, sparco etc.
i was woundering are Sabelts any good?
i just bout a set of simpson camlock belts for my car. Total cost was $353 out the door (for two pairs of 5-point belts and mounting hardware). I could have spent more on schroth belts (@ $250/ea) but i didnt see the need to....
RJ
RJ
Could it also be a saftey issue? from what i see the cam-locks release everything right away, letting the driver to leave the car faster then the other types of locking device.
Latch links release instantly, too. It's when you put them on that it's more of a pain in the butt. Some people like it, some don't. There has also been stories of certain cam-lock styles releasing unintentionally when a sleeve or something has caught on the lever. I personally went with camlock and tried them out for the first time this evening on my way home.
AutoPower seems to be a great deal also
5 point cam harnesses for $150 each from ioport.
The cam release is by turning the buckle, which would be harder to accidentally release than one of the levers
G-force belts are about the same price ~$160 each i think.
without a rollbar you know the danger your putting yourself in right?
have a
how you spend more on ONE harness , than you can buy a pair with the hardware for is beyond me.
Besides the cheaper harness wouldn't be JDM . . .
