F22 intake
What F22, F22A1-6, SOHC F22B1-2 or the DOHC F22B?
The F22A and DOHC F22B will fit the SOHC F22B1-2 will not.
The F22A IM has a smaller throttle body opening and upper plenum. the primary and secondary IAB runners are longer. If that is what you are looking for it would work. Most people looking for a boost in power go with a Euro R intake on the H22 or remove the IABs and add a spacer. The Euro R is a solid manifold with a single set of shorter runners and a larger throttle body opening.
