Will a 01 GSR Alternator fit in a 01 ITR
Old Feb 25, 2012 | 10:12 AM
ek9_B18C's Avatar
Icon2 Will a 01 GSR Alternator fit in a 01 ITR
Well my 01 ITR is acting up my with idle issues and poor gas milage(17mpg). I was thinking that it might be the alternator since im only getting 10-20 amps from it and if i turn on all the accessories I get 0 amps. Anyways I'm shoping around for a Alternator but all the 01 ITR alternator are running for over 220 buck, but yet the 01 GSR alternators are about 120 bucks. They both put out 90 amps but are the housing the same? I read that the 97 ITR/GSR were the same but the 01 have differnt part numbers.
Old Feb 25, 2012 | 10:14 AM
Dc4LsTeG's Avatar
EK9
Default Re: Will a 01 GSR Alternator fit in a 01 ITR
It will work
Old Feb 25, 2012 | 12:18 PM
ek9_B18C's Avatar
so whats the diffence? why the extra 100 bucks
Old Feb 25, 2012 | 12:28 PM
94sicteg's Avatar
depends on where your going really cause i can g to oriellys and get a starter for a 00 si civic it will be one price then look up a 00 integra and be different part number all together and different price weird cant control.i just know what things fit others helps me save money
Old Feb 25, 2012 | 01:35 PM
ek9_B18C's Avatar
do you think the 00 si alternator would work?
Old Feb 25, 2012 | 01:36 PM
94sicteg's Avatar
yes
Old Feb 25, 2012 | 01:50 PM
ek9_B18C's Avatar
hey thanks , but it looks like the gsr is the cheapest.
Old Feb 25, 2012 | 10:34 PM
01typerboi's Avatar
Yes it will work. Most bseries parts are interchangable. Just keep in mind that you want something in the same obd series. Yes i know 01 gsr and 01 itr are same obd series i was just adding a friendly reminder if you start looking at other electrical components down the road.
Old Feb 26, 2012 | 08:48 AM
Slow@ssLuda's Avatar
I tried this about a month ago on my 00 ITR. It didnt work at all, everything plugs in and the bottom bolts up fine but the top bolts up at the very end of the bracket and the alternator hits the block. it's a close fit but you wont have any adjustablity to tighten the belt. Just spend the extra 100 dollars you will thank me for it later.
Old Feb 26, 2012 | 04:47 PM
00-1065's Avatar
You can always send your existing alternator to be rebuilt.
Old Feb 26, 2012 | 05:49 PM
ekcoupeh22's Avatar
I've used every alternator out there with no problems
Old Feb 26, 2012 | 05:53 PM
Dc4LsTeG's Avatar
EK9
Uhh I have a gsr alternator on my b18c5 and don't have this problem
Old Feb 26, 2012 | 06:29 PM
I wish i could say the same but i have a GSR one sitting in my garage collecting dust
Old Feb 26, 2012 | 06:31 PM
Dc4LsTeG's Avatar
EK9
Well Idk. Mine fits perfect. And I'm using the stock p73 alternator bracket
Old Feb 26, 2012 | 07:14 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
I don't see how. I don't have this problem. All obd2 alts are the same. They just charge more cause its a itr.
Old Feb 27, 2012 | 04:45 PM
ek9_B18C's Avatar
So I guess the 99-00 SI are all obd2b so that wont work, and I looked at rebuilding mine since it only has 18k on the moter, but just the regulator at o'reillys was 250.00. Cheaper to buy a rebuilt one.
DC4: Whats up with that wing on your hatch? What does it do set at that angle?
jspecjoe
Apr 7, 2006 08:49 PM
ITR-00-1457
Apr 3, 2004 10:10 AM
deeksmooth
Audio / Security / Video
11
Jan 3, 2004 12:06 AM
ITR 00-1567
Dec 13, 2002 09:31 PM
el402
May 16, 2002 10:38 PM
