coolant sensor / o2 sensor
Just need to confirm the wiring of these two sensors on a stock 1990 civic si? Anybody feel like checking the colors? Maybe I got mine mixed, not sure....
OBDO.
It's the wire connected directly to the coolant sensor I have in question. And, or the engine harness wire for the o2 sensor. Just need to make sure I dont have these two swapped. Thanks for your help, si-r.
Been rebuilding a basket. The harness was hacked, connectors missing. These two wires/sensors are the last in question.
One wire is black and of a slightly heavier gauge is that the one for the o2 connector? I've been soldering and extending what's left of the harness.
Thanks for your help. Sorry if I have not been clear.
neither sensor should have a black wire. the o2 sensor wire will be shielded (gray silicone cover with white wire under neath), and the water temp should be yellow/green
turbotime
Dec 6, 2006 06:40 AM
BlueShadow
Dec 1, 2005 08:10 PM
