Power window works fine until the last 1/2 inch at the top
Old Feb 24, 2012 | 05:12 PM
dlstech's Avatar
Default Power window works fine until the last 1/2 inch at the top
So my power window needs help in the last half inch to stay up. It goes up and down fine but at the top it just clicks and jumps but won't go all the way up on it's own. Is this something that can be fixed or should I just get a new regulator since they're like $30 on ebay?
And if I get one, can I swap my old motor? Or should I get one with a motor? I remember trying to swap a motor on my jetta regulator and it just falls apart and is nearly impossible.
Old Feb 24, 2012 | 05:37 PM
Will_GT90's Avatar
Default Re: Power window works fine until the last 1/2 inch at the top
From what I can tell this sounds exactly like a regulator, I would remove the door panel and look inside the panel for the regulator as you go up/down with the window before I blew the $30, but if you don't care buy it and hope thats it. Always a safer bet to not end up with extra parts though.
Old Feb 24, 2012 | 06:30 PM
ej1love's Avatar
havin same problem, if you mess with the regulator; OP let us kno the results
Old Feb 24, 2012 | 07:15 PM
deving916's Avatar
is the regulator being held by all 4 bolts? I had a similar issue and it was because 3 bolts were missing and the regulator had a lot of play to move.
Old Feb 25, 2012 | 08:59 AM
motegicivic's Avatar
You can separate the regulator from the motor I think it is a couple of screws, chances are it is the regulator. If you can get a regulator and motor together cheap then go that route.
Old Feb 25, 2012 | 09:37 AM
95dxsir2's Avatar
i would also check the window channel seal (might have folded). the seal that the window sets in as it goes up and down. like others say, check the mounting of the regulator/motor. it sounds like it's binding when it gets to the top and stops.
Old Feb 25, 2012 | 03:47 PM
D16SiHatch's Avatar
Sounds like what mine did when the teeth on the regulator wore down and stripped out. You can purchase just the regulator or both regulator and motor for fairly cheap if you need that as well.
wizarddrummer
Sep 4, 2012 10:44 AM
Mufasa
Jul 4, 2011 12:27 AM
Dub C
Oct 8, 2010 05:49 PM
Gennady
Jun 18, 2002 05:23 PM
