NC 1993 Honda Delsol(352whp turbo,tucked,tons of aftermarket!!!)
Old Feb 24, 2012 | 02:47 PM
norcarsol's Avatar
Default 1993 Honda Delsol(352whp turbo,tucked,tons of aftermarket!!!)
contact:post pm call or text 3363926399
the time has come to part ways and start something new
very interested in a stock or modded s2000 and eg hatchbacks would prefer a b series vtec setup or k series in it. modifications will determine what kind of cash on your end but will entertain all trades so shoot them at me trade value is $8000 would take less if paying cash but would prefer trade plus cash or straight trade of something of equal value.
here's a list of items i've purchased for the car
there is much more i'm sure but this is all i can think of at this time.
engine/turbo:
gsr block with b16 head
gsr cams with full race cam gears
itr valvetrain
super fresh head gasket
arp head studs
omni 4 bar map sensor
omni tps sensor
omni 70mm throttle body
victor x intake manifold
t04e 60/63 Turbo
synapse synchronic wastegate
synapse synchronic bov w/ tial 50mm flange adapter
deatschwerks 300 lph fuel pump
siemens deka 630cc pencil injectors
emusa intercooler
custom 2.5'' intercooler piping w/ tial 50mm flange and obd1 iat relocation
custom oil feed and return made by local hydraulic store.
blueridge motorsports battery tray catch can w/6 -10an ports
custom -10an catch can lines
golden eagle lsv 1/8th sandwich plate kit
go autoworks block pcv kit and box delete
spa top mount manifold
innovate mtx-l wideband
autometer phantom boost gauge
autometer phantom oil psi gauge
98 spec itr transmission with stock lsd
new axles and axle seals
competition stage 4 6puck sprung clutch kit
fidanza lightweight flywheel
russel inline fuel filter
-6an flexlite russel fuel feed line conversion
tucked braided clutch line
blox cam seal
black valve cover with 4 -10 an bungs
aluminum spark plug cover
purple nology spark plug hotwires
socketed p28 chipped on crome
gsr oil pan with -10 an bung welded
thermal intake manifold gasket
thermal throttle body gasket
custom 3'' downpipe also comes with up pipe for track days.
aluminum half radiator
12'' slim fan
new oem inner and outer tie rods
oem oil pan gasket
full hardline brake tuck and wire tuck
i'm sure there's a ton more i'm forgetting but just ask if you have any questions
this setup made 352 on 13 psi tuned by joseph davis with a sc61 just very laggy new turbo should spool alot faster maybe not make as much peak power.can provide video showing the power it made on the dyno along with the dyno plot.
exterior:
coilover sleeves with camber kits all the way around
stock delsol wheels with tons of life left on tires
sickspeed velocity stack into turbo inlet
benen tow hooks front and rear (orange)
very stock looking outside of the car other than these few things definitely a sleeper.
brand new pads rotors calipers all the way around as well.
interior:
has just a couple minor flaws needs driver side door handle very common on sols has rare no stripe del sol seats
3 gauge pillar pod and complete stock clean interior
with ipod compatible head unit.
all underhood fuseblock wiring has been relocated to behind passenger seat in the lockbox compartment zero issues with anything on this car.
car runs perfect just ready to start something new a little more practical for daily driving.
Now onto pics will get others of interior and such if you need anything in particular just ask and i can take a couple snaps for you.
v1sion
Northern California (Sales)
Sep 20, 2010 09:56 PM
civic4lif
Oct 6, 2009 12:44 PM
dopeyesw310
Jul 26, 2009 07:23 AM
walker93
Mid-Atlantic (Sales)
12
May 10, 2009 05:31 PM
